The difference between the API and the SDK and the benefits of the SDK.
tomhiddleston
An API is an interface that allows software programs to interact with each other, while an SDK is a set of tools that can be used to develop software applications targeting a specific platform. The simplest version of an SDK might be an API that contains some of the files needed to interact with a particular programming language. So an API can be seen as a simple SDK without debugging support, etc.
The SDK allows you to have various features in your application that help provide a good user experience. For example, providing exact location in the application, quick and easy integration, accuracy of data and deployment, and path enhancement, and elimination when no longer needed.
