S32k142 SDK FATFS example
2,800 次查看
Teja114
Hi there,
i Downloaded S32K142 sdk.
On the middleware folder i didn't find sdcard example.
can you please guide me!!!!
Thanks in advance!!!!
2,700 次查看
lukaszadrapa
the message talks about SDK for Cortex M. That's definitely not SDK for MPC5748G.
SDK for MPC5748G is included in S32 Design Studio for Power architecture:
https://www.nxp.com/design/software/development-software/s32-design-studio-ide/s32-design-studio-for...
Lukas
8 回复数
2,735 次查看
Teja114
2,773 次查看
Teja114
The link you provided  is a power architecture IDE will it supports the S32 design studio mean can i import the project of power architecture IDE in S32design studio..
2,747 次查看
lukaszadrapa
projects for ARM and for PowerPC are not compatible, it's completely different architecture.
There are two separate versions of S32 Design Studio for ARM and for PowerPC.
Lukas
2,776 次查看
lukaszadrapa
S32K1xx devices don't have SDHC module. It was not expected use-case, so we do not have such example or drivers for this device.
If you are going to use SPI mode, you can use some general drivers where you can port SPI layer only.
And if we are talking about automotive devices then MPC5748G have SDHC module and it's supported in SDK:
https://www.nxp.com/products/processors-and-microcontrollers/power-architecture/mpc55xx-5xxx-mcus/ul...
Lukas
2,713 次查看
Teja114
unable to download MPC5748G  sdk .
can you please help me on this
2,708 次查看
Teja114
2,701 次查看
lukaszadrapa
Lukas
2,774 次查看
Teja114
