Does IAR compiler for S32K148 support printing 64bit integers (%lld, %llu, %llx) with snprintf() function?
I have a strange behavior in my application. When I add one global uint32_t variable, then snprintf() prints 64bit integers with %lld incorrectly (shifted). When I remove this additional variable or add one more global uint32_t then it prints the 64-bt int with %lld correctly.
32-bit integers are printed correctly in both cases.
Any idea what could be the cause?
已解决! 转到解答。
 lukaszadrapa
			lukaszadrapa
		Hi Jakub,
after short discussion with our S32DS expert, our recommendation is to forward this to IAR as we can't help here.
Lukas
