S32K144 I2C
S32K144 I2C
1,017 次查看
wanglijun
In the S32K144 datasheet, about the I2C module, there is a register: MFCR.
Can you explain the register application?
Thank you!
942 次查看
danielmartynek
Hello wanglijun,
As explained in the reference manual, the register basically defines when the Receive/Transmit Data flags are set.
