S32K LIN
S32K LIN
3,110 次查看
chenze
     I recently met a problem about Lin communication,the version I use is S32DS_ARM_Win32_v2.2,and the lin  component I use is lin,not lin stack,the lin is master,the LPUART is LPUART1,when I init the lin by LIN_DRV_Init and LIN_DRV_InstallCallback,The interrupt function LIN_LPUART1_RxTx_IRQHandler is immediately entered,The program enters the if statement as shown below, I don't know what happened, and I don't know how to fix it,someone can help me ,thank you very much.Note: I used freeRTOS.
标记 (1)
3,090 次查看
PetrS
have you also configured LPUART pins properly and have connected LIN transceiver that is active?
BR, Petr
3,017 次查看
chenze
Now my problem has been solved, thank you very much。
