S32DS and S32K1XX SDK on Linux
2,727 次查看
gabriel_robert
I'm trying to use S32DS SDK on Linux, but it's not possible to install it from "Install New Software" :
Cannot complete the install because some dependencies are not satisfiable
com.nxp.s32ds.cross.sdk.s32k1xx_2.9.2.brc.feature.group [1.0.0.201811280640] cannot be installed in this environment because its filter is not applicable.
I tried other versions of the SDK, doesn't works too.
I'm using S32 Design Studio for ARM Version 2018.R1 on Ubuntu 18.04 LTS 64 bits.
Thank you.
2,494 次查看
jiri_kral
the SDK is not supported on Linux Host. Sorry for any inconvenience.
Jiri
2,495 次查看
jiri_kral
Jiri
