S32 Design Studio: How to upgrade SDK version of an existing project?
2,101 次查看
sripav-7
Hello
I have an existing project developed using the EAR 0.8.6 SDK and I would like to upgrade it to 1.9.0 BETA SDK but can't figure out a way to do it. Can someone please guide me through?
Thank you
标记 (4)
1,724 次查看
jiri_kral
these versions aren't fully compatible. You can try export PE settings, but some module you will need to configure manually. The only 100% working solution is create  new project with SDK you are interested in, add your sources and create new Processor Expert settings.
I recommend you use SDK v2.0 RTM instead the 1.9 beta.
Jiri
