Processor Expert Initialization Sequence
2,972 次查看
lucabarbiero
Working with S32 SDK for Power Architecture, I define ordered initialization sequences for ProcessorExpert components, like this:
However, I don't see any effect on the generated code. I would expect an initialization function to be generated, which contains ordered function calls to the init function of my PE components. After searching around in the web about this feature, I noticed that people talk about a PE_low_level_init() routine. But I don't have it.
Am I missing something or is this feature just not available for real in S32 SDK for Power Architecture?
2,938 次查看
PetrS
seems this is really not functional for Power Architecture.
There is no function generated by PE which summarizes peripherals init or similar.
User need to place Init functions in code by own.
BR, Petr
2,936 次查看
lucabarbiero
Hello, thank you for the confirmation. This confirms what I had concluded as well.
2,939 次查看
PetrS
BR, Petr
