PIT interrupt code is disabled
Dev15
Hi Team,
I have configured PIT0 and PIT1. The ISR is not getting interrupted as expected as the code is disabled in "Pit_Ip.c" file.
Please find the attached screen shot for reference and help to resolve the same.
RTD 3.0.0 version is used
Dev15_0-1710786343442.pngt
Dev15
@Senlent , Thank you. It is working fine now.
Senlent
Hi@Dev15
I did some tests on the routines provided by the IDE.
Attached is the project I modified. I hope it will be helpful to you.
Dev15
