Project is created from S32K144 EAR SDK Example Projects. But there is no communication with UART. The same code is working with Interrupts. I have changed lpuart_user_config_t lpuart1_InitConfig0. (.transferType = LPUART_USING_DMA,)
Am I missing any configuration?
已解决! 转到解答。
to be able use eDMA data transfer mode - you also need init eDMA driver by adding this line in the main function:
EDMA_DRV_Init(&dmaController1_State, &dmaController1_InitConfig0);
front of UART init.
Another suggestion from SDK team is to use latest RTM SDK version. Lot of bugs is fixed there.
Jiri
front of UART init.
Jiri
I tried LPUART example - and for me even the interrupt mode is not working correctly. I can get welcome message, but no response to typing. I sent email to SDK team for solution and I'll respond when I get answer.
Jiri
