How to upload the .ldf file while configuring the LIN stack?
2,400 次查看
svsagar92
Issue: Unable to upload the .ldf file.
Could you please help on above issue. When i'm browsing for the file too, unable to find the ldf file.
标记 (4)
1 回复
2,293 次查看
dianabatrlova
Hello Vidyasagar,
At first, I would like to recommend you to look at the S32DS lin_master example. The LDF file is located in the Sources folder. You can modify according to your needs.
For example, see the image below:
I hope it helps.
Diana
