How to upload the .ldf file while configuring the LIN stack?
svsagar92
Issue: Unable to upload the .ldf file.
Could you please help on above issue. When i'm browsing for the file too, unable to find the ldf file.
dianabatrlova
Hello Vidyasagar,
At first, I would like to recommend you to look at the S32DS lin_master example. The LDF file is located in the Sources folder. You can modify according to your needs.
For example, see the image below:
I hope it helps.
Diana
