How can i change the package in S32DS and generate code that can compile successfully?
1,718 次查看
timwang
When i change the package of the processor MPC5748G and generate code,if i build the project,there are some faults exist like this:
How can i use the PE tool to change the pacage of processor and add some other components?
When i add some other components,it also can't compile successfully.
Thanks!
1,484 次查看
stanish
there is a document describing switching the package, it should be the same process for S32DS Power.
 https://community.nxp.com/docs/DOC-334936
S.
