what's the default login name and password of pre-build sd-card image based on debian rootfs?
已解决
跳至解决方案
4,035 次查看
建华董
I'v booted sucessfully from sd-card on s32v234 evb board,but i can't login the system.
1 解答
3,841 次查看
建华董
Yes,I have got the solution from nxp local representive.
Below is how you can set the password to whatever you want with a few commands:
1. Stop at u-Boot stage by pressing any key after "Hit any key to stop autoboot" appears.
2. Modify the environment as specified below and boot:
    => setenv mmcroot /dev/mmcblk0p2 rootwait rw init=/bin/sh
    => boot
    do _not_ issue "saveenv".
3. You will be presented a root shell without any authentication.
   Use  "passwd" command to set the password to whatever you want:
    #/usr/bin/passwd vision
    #sync
4. Powercycle the board.
5. When the system boots and comes to login, enter "vision" as username and the password you set.
在原帖中查看解决方案
2 回复数
3,841 次查看
sumit_shrestha
Did you get the username and password? Even I am currently struggling with the same thing.
3,842 次查看
建华董
    => boot
    #sync
