the error"first defined here
1,192 次查看
609510318
S32 Design Studio for Arm.when the project was built all firstly, the error"first defined here" was happened,what is the reason?
Notes:The lib file contained the functions with the error. Was the way that the lib was input into the project is wrong?
Thanks for your answer
标记 (2)
1,101 次查看
jiri_kral
what's your project? It is an included example? Can you shared output from build console?
Jiri
