Inside the Pins view, inside the Package, Pins and Routing Details windows, every pin is referred to by their Port/Pin denomination and their Pin Number.
The Peripherals view however works with PCR exclusively.
To make working easier, I highly recommend adding the PCR to Pins view as well.
Hovering over a Pin in the Package window should show the PCR.
The Pins and Routing Details windows should have a column that shows the PCR.
The Signal Description IO Multiplexing sheet should have column that shows the PCR.
This would make working between the two views significantly easier.
