[src/Project_Settings/Startup_Code/subdir.mk:42: src/Project_Settings/Startup_Code/startup_cm7.o]
TK6
HI NXP Experter:
Now, I am using S32DS.3.5-S32 Design Studio,This error is reported during compilation:Description Resource Path Location Type
make[1]: *** [src/Project_Settings/Startup_Code/subdir.mk:42: src/Project_Settings/Startup_Code/startup_cm7.o] Error 1 S32K322_Ghs_Project C/C++ Problem.
May I ask what caused this, thank you.
jiri_kral
can you please share full output from build console?
