some question about S32KDS
binhuang
I have some question about S32KDS as follow,
1, Could you help to explain the effect of the red frame(“Section –j.text””Section –j .data” “Other Sections”)
2,where had it come from about "${ProjDirPath}" ,I do not find it in the S32KDS. about this type macros,could you help to list it ,explain the default vaule and definition rules
jiri_kral
you can chose any particular section to be part of flash image (the standard one like .data or .text) - or you can add your custom sections. If no section is selected - all sections are part of flash image.
Build  variables are in C/C++ Build -> Build Variables. Each project is using general variable name (like $ProjDirPath) - but each project has it's own value of that variable:
Jiri
