s32ds arm Activation failed
duosahnyu
After I reinstalled S32DS, I encountered the error message "Your software Activation Code is for another feature" when using the activation code 60CA-0D4F-9A08-3EEB.
Could you please help me check this issue? The attached file is my installation logerror.pngerror.png
duosahnyu
After I clicked the Cancel button, the error message appeared: "software activation code is already used on this station for 3 Activated 2.2"
jiri_kral
I checked your account and it looks that you was able activate S32DS on Thursday, is that correct?
duosahnyu
Yes, the activation issue has been resolved.
However, when I open S32DS and create a new project for the S32K144, an error pop-up window saying "Unsupported or unrecognized format" appears when I expand the project folder. The pop-up cannot be closed normally.
Despite this issue, the project seems to compile normally. Could you please help me understand what causes this error?
jiri_kral
can you please share the project? It is possible that the project is affected by some encryption from OS.
