mpc5777c
mpc5777c
3,733 次查看
saichinnala
Hai,needed a example code for Esci module on mpc5777c with dual wire
3 回复数
3,707 次查看
davidtosenovjan
Pay attention to MPC5 cookbook, example 15/16:
https://www.nxp.com/docs/en/application-note/AN2865.pdf
It is applicable also to MPC5777C as it used the same eSCI module.
I am using eSCI also for printf funtionity in the base project below:
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/Example-MPC5777C-PinToggleStationery-GHS714/ta-p...
3,699 次查看
saichinnala
by adding your code am unable to build
@davidtosenovjan
3,571 次查看
stanish
I'm afraid the example was created for GreenHills development environment - Multi.
I'd suggest you to create a new S32DS multicore project (GCC compiler) and fit the relevant code to the pre-generated multicore project structure.
Hope it helps.
Stan
