laxcc help
laxcc help
PeterSmithson
I'm trying to work on a customer issue. They are using the S32 Design suite which is launching the laxcc compiler. I've downloaded a copy and I can run laxcc but I can't find any documentation on it. When I run it with -help, it claims to be a compiler called it3a-cc.
Specifically, what does the -env option do? The help says
" -env # specify a non-standard environment path"
What is an environment path and what would a standard one be?
Thanks.
Peter
