can not rename
can not rename
4,447 次查看
maojun
V2.0    0.8.6      S32K144
I can not rename my project. did anynone know how to fix this problem?
标签 (1)
标记 (3)
4 回复数
4,173 次查看
jiri_kral
Is your project active one? Can you please share full screenshot of your S32DS? You can rename active S32DS project by F2 key or on Main menu bar File ->Rename. For me are both methods working okay.
Jiri
4,173 次查看
maojun
    this is my full screenshot,I used F2 key to rename my project,but it pops this .
4,173 次查看
jiri_kral
your project is not part of workspace - you probably opened it as project from file system.
Importing project into workspace should solve your issue:
and select your project directory or project zip archive:
Jiri
4,173 次查看
maojun
It really works,thank you very much.
