c and assembly mixed programming
2,642 次查看
wenchaohu
how to use a variable defined in C in  assembly in S32DS with MPC5744P?please give me some suggestions
2,425 次查看
martin_kovar
unfortunately, I do not have any example, but I can redirect you to usable website. The thing you are searching is called extended assembler. Please see then link below. The only thing you must study is how to use this with VLE instruction set.
Extended Asm - Using the GNU Compiler Collection (GCC)
I am also attaching you VLE manual.
Hope it helps a little bit.
Martin
