build project error as the following message
1,792 次查看
hicensezhang
when I build the project, the result report error as the image , could you help it? thank you
1,484 次查看
mikedoidge
Hello @hicensezhang.
What is the version of the S32K144 SDK you are using? S32 SDK RTM 4.0.3 is the latest.
I see that the make command in your screen capture shows as: make -j4 all
However, when I build this same project, the make command is: make -j20 all
Did you change some settings on this project?
Mike
