arm-none-eabi-gcc: command not found
18,495件の閲覧回数
Chakradhar
below is the error am facing while building the HSE_Demoapp in S32DS S32K3X2
can any one help me,
Building file: ../Project_Settings/Startup_Code/Startup.s
Invoking: Standard S32DS Assembler
arm-none-eabi-gcc "@demo_app/Startup.args" -o "demo_app/Startup.o" "C:/Temp/NXP/HSE_DEMOAPP_S32K3X2_0_0_11_0/demo_security_installer/src/demo_app/target/m7/startup/Startup.s"
arm-none-eabi-gcc "@demo_app/Vector_core.args" -o "demo_app/Vector_core.o" "C:/Temp/NXP/HSE_DEMOAPP_S32K3X2_0_0_11_0/demo_security_installer/src/demo_app/target/m7/startup/Vector_core.s"
arm-none-eabi-gcc "@Project_Settings/Startup_Code/Startup.args" -o "Project_Settings/Startup_Code/Startup.o" "../Project_Settings/Startup_Code/Startup.s"
Building file: ../Project_Settings/Startup_Code/Vector_core.s
/bin/sh: arm-none-eabi-gcc: command not found
make: *** [demo_app/subdir.mk:19: demo_app/Startup.o] Error 127
make: *** Waiting for unfinished jobs....
arm-none-eabi-gcc "@Project_Settings/Startup_Code/Startup.args" -o "Project_Settings/Startup_Code/Vector_core.o" "../Project_Settings/Startup_Code/Vector_core.s"
make: *** [Project_Settings/Startup_Code/subdir.mk:19: Project_Settings/Startup_Code/Startup.o] Error 127
make: *** [demo_app/subdir.mk:26: demo_app/Vector_core.o] Error 127
make: *** [Project_Settings/Startup_Code/subdir.mk:19: Project_Settings/Startup_Code/Vector_core.o] Error 127
"make -j12 all" terminated with exit code 2. Build might be incomplete.
13 返答(返信)
4,234件の閲覧回数
millerhughes
Under my case: windows 11 on 2026
add modified environmental variable  below is validated by our IT
CC_LIB=C:\NXP\S32DS.3.6.4\S32DS\build_tools\gcc_v9.2\gcc-9.2-arm32-eabi\arm-none-eabi\newlib\lib\
15,695件の閲覧回数
nirmal_masilamani
I am also facing same kind of issue with DIO example project with RTD.
17:37:45 **** Build of configuration Debug_FLASH for project Dio_Example_S32K144 ****
make -j12 all
Building file: ../generate/src/Dio_Cfg.c
Building file: ../generate/src/Clock_Ip_VS_0_PBcfg.c
Building file: ../generate/src/Mcu_Cfg.c
Building file: ../generate/src/Clock_Ip_Cfg.c
Building file: ../src/main.c
Building file: ../generate/src/Mcu_VS_0_PBcfg.c
Invoking: Standard S32DS C Compiler
arm-none-eabi-gcc "@generate/src/Clock_Ip_Cfg.args" -MMD -MP -MF"generate/src/Dio_Cfg.d" -MT"generate/src/Dio_Cfg.o" -o "generate/src/Dio_Cfg.o" "../generate/src/Dio_Cfg.c"
arm-none-eabi-gcc "@src/main.args" -MMD -MP -MF"src/main.d" -MT"src/main.o" -o "src/main.o" "../src/main.c"
arm-none-eabi-gcc "@generate/src/Clock_Ip_Cfg.args" -MMD -MP -MF"generate/src/Clock_Ip_Cfg.d" -MT"generate/src/Clock_Ip_Cfg.o" -o "generate/src/Clock_Ip_Cfg.o" "../generate/src/Clock_Ip_Cfg.c"
make: *** [src/subdir.mk:20: src/main.o] Error 127
make: *** [generate/src/subdir.mk:55: generate/src/Dio_Cfg.o] Error 127
arm-none-eabi-gcc "@generate/src/Clock_Ip_Cfg.args" -MMD -MP -MF"generate/src/Clock_Ip_VS_0_PBcfg.d" -MT"generate/src/Clock_Ip_VS_0_PBcfg.o" -o "generate/src/Clock_Ip_VS_0_PBcfg.o" "../generate/src/Clock_Ip_VS_0_PBcfg.c"
arm-none-eabi-gcc "@generate/src/Clock_Ip_Cfg.args" -MMD -MP -MF"generate/src/Mcu_VS_0_PBcfg.d" -MT"generate/src/Mcu_VS_0_PBcfg.o" -o "generate/src/Mcu_VS_0_PBcfg.o" "../generate/src/Mcu_VS_0_PBcfg.c"
arm-none-eabi-gcc "@generate/src/Clock_Ip_Cfg.args" -MMD -MP -MF"generate/src/Mcu_Cfg.d" -MT"generate/src/Mcu_Cfg.o" -o "generate/src/Mcu_Cfg.o" "../generate/src/Mcu_Cfg.c"
make: *** [generate/src/subdir.mk:56: generate/src/Clock_Ip_Cfg.o] Error 127
make: *** [generate/src/subdir.mk:56: generate/src/Clock_Ip_VS_0_PBcfg.o] Error 127
make: *** [generate/src/subdir.mk:56: generate/src/Mcu_VS_0_PBcfg.o] Error 127
make: *** [generate/src/subdir.mk:56: generate/src/Mcu_Cfg.o] Error 127
17:37:46 Build Failed. 13 errors, 0 warnings. (took 886ms)
18,173件の閲覧回数
Chakradhar
@VaneB Eventhough I followed the same steps mentioned same error am facing same issue,
I gave PATH Variable : C:\Temp\NXP\S32DS.3.5\eclipse;C:\Temp\NXP\S32DS.3.5\S32DS\build_tools\msys32\usr\bin;C:/Temp/NXP/S32DS.3.5/eclipse/jre/bin/client;C:/Temp/NXP/S32DS.3.5/eclipse/jre/bin;C:\windows\Softcamp\SDK;C:\windows\Softcamp\SDS\x64;C:\windows\Softcamp\SDS;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\Program Files\Windchill\RVSClient12\bin;C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Iqpad\ubCENTRA\;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;C:\Program Files\Bandizip\;C:\Program Files\PuTTY\;C:\Program Files (x86)\Vector CANdb++ 3.1\Exec32;C:\Program Files\dotnet\;C:\Program Files (x86)\dotnet\;C:\PROGRA~1\WINDCH~1\Toolkit\mksnt;C:\Program Files\TortoiseGit\bin;C:\Program Files\Git\cmd;C:\Program Files\CMake\bin;C:\Program Files\Polyspace\R2022b\polyspace\bin;C:\Users\mobis\AppData\Local\Programs\Python\Python311\Scripts\;C:\Users\mobis\AppData\Local\Programs\Python\Python311\;C:\Users\mobis\AppData\Local\Microsoft\WindowsApps;C:\Program Files\Git\cmd;C:\Program Files\TortoiseGit\bin;C:\Temp\bin;C:\Temp\NXP\S32DS.3.5\S32DS\tools\gdb-arm\arm32-eabi\bin
18,101件の閲覧回数
VaneB
Hi @Chakradhar
Sorry for the inconvenience this may cause.
I am not able to reproduce your issue because, as I mentioned, SAF85XX is not a mass-market device, I am not able to check or verify any information due to the security level when working with automotive parts such as this.
Could you please contact the person who provided you with the device for further support on this part?
18,470件の閲覧回数
VaneB
Hi @Chakradhar
From the information provided, I assume that you are using the HSE Firmware Standard EAR release compatible with S32K312 Device (s32k3x2_hse_fw_0.13.0_0.11.0_pb210726.bin (FullMem) and s32k3x2_hse_fw_1.13.0_0.11.0_pb210726.bin (AB Swap)). We always recommend using the latest release.
Regarding the building problems, could you confirm if you followed the steps described in the Read Me file to import and build the project?
B.R.
VaneB
18,444件の閲覧回数
Chakradhar
@VaneB  i have followed the readme file and  i have downloaded latest file HSE_DEMOAPP_S32K311_0_2_14_0 and am facing the below error
No rule to make target 'C:/Temp/NXP/HSE_DEMOAPP_S32K311_0_2_14_0/demo_security_installer/src/demo_app/target/m7/src/sys_init.c', needed by 'demo_app/target/m7/src/sys_init.o'
I am working for SAF85XX product (HSE_M (Medium) is available on Flash-less S32x product variants (such as S32R41 and SAF85)) need this
even though i have tried to open the demo_app_m7_0.gpj(HSE_B is there) with GHS
facing error with Could not read target file : arm_standalone.tgt
18,418件の閲覧回数
VaneB
Hi @Chakradhar
Please correct me if I understand wrong.
It is not recommended to use HSE B for SAF85XX devices as this is not the version need it.
Also, as SAF85XX is not a mass-market device, I am not able to check or verify any information due to the security level when working with automotive parts such as this. Could you please contact the person that provided you with the device for further support on this part?
18,395件の閲覧回数
Chakradhar
@VaneB Can you say how to resolve the arm-none-eabi-gcc: command not found please
18,377件の閲覧回数
VaneB
Hi @Chakradhar
Usually, this error is caused because a build error for installing HSE FW.
I want to ask you to verify the version of your IDE. At the moment of creation, the project was done for S32DS v3.5. Please check this from Help -> About S32 Design Studio.
Also, the S32K3 extension package needs to be installed as well.
18,314件の閲覧回数
Chakradhar
S32 design details
S32 Design Studio for S32 Platform
Version: 3.5
Build id: 220726
Copyright 2017-2022 NXP
Visit http://www.nxp.com/
This product includes software developed by the Eclipse Foundation http://www.eclipse.org/
This product includes software developed by the Apache Software Foundation http://apache.org/
18,293件の閲覧回数
VaneB
Hi @Chakradhar
The IDE version is correct, so the problem will be a miss of a package that is necessary for the HSE_DEMOAPP_S32K311_0_2_14_0. Please make sure to have the S32K3 extension package installed as well.
18,265件の閲覧回数
Chakradhar
Hello @VaneB am getting this error
just i have build the project "HSE_DEMOAPP_SAF85xx_1_0_23_2" in S32 Design studio
Issue:
**** Build of configuration BuildConfig_Flash for project HSE_DEMO_SAF85XX ****
make -j12 all
Building file: ../src/sys_init.c
arm-none-eabi-gcc "@src/sys_init.args" -MMD -MP -MF"src/sys_init.d" -MT"src/sys_init.o" -o "src/sys_init.o" "../src/sys_init.c"
Building file: ../generate/src/Fls_Cfg.c
arm-none-eabi-gcc "@generate/src/Clock_Ip_Cfg.args" -MMD -MP -MF"generate/src/Fls_Cfg.d" -MT"generate/src/Fls_Cfg.o" -o "generate/src/Fls_Cfg.o" "../generate/src/Fls_Cfg.c"
Building file: ../generate/src/Fls_VS_0_PBcfg.c
arm-none-eabi-gcc "@generate/src/Clock_Ip_Cfg.args" -MMD -MP -MF"generate/src/Fls_VS_0_PBcfg.d" -MT"generate/src/Fls_VS_0_PBcfg.o" -o "generate/src/Fls_VS_0_PBcfg.o" "../generate/src/Fls_VS_0_PBcfg.c"
Building file: ../generate/src/OsIf_Cfg.c
arm-none-eabi-gcc "@generate/src/Clock_Ip_Cfg.args" -MMD -MP -MF"generate/src/OsIf_Cfg.d" -MT"generate/src/OsIf_Cfg.o" -o "generate/src/OsIf_Cfg.o" "../generate/src/OsIf_Cfg.c"
Building file: ../generate/src/Qspi_Ip_VS_0_PBcfg.c
arm-none-eabi-gcc "@generate/src/Clock_Ip_Cfg.args" -MMD -MP -MF"generate/src/Qspi_Ip_VS_0_PBcfg.d" -MT"generate/src/Qspi_Ip_VS_0_PBcfg.o" -o "generate/src/Qspi_Ip_VS_0_PBcfg.o" "../generate/src/Qspi_Ip_VS_0_PBcfg.c"
Building file: ../board/Siul2_Port_Ip_Cfg.c
Using built-in specs.
Reading specs from nano.specs
arm-none-eabi-gcc.exe: error: nano.specs: No such file or directory
make: *** [src/subdir.mk:20: src/sys_init.o] Error 1
arm-none-eabi-gcc "@board/Siul2_Port_Ip_Cfg.args" -MMD -MP -MF"board/Siul2_Port_Ip_Cfg.d" -MT"board/Siul2_Port_Ip_Cfg.o" -o "board/Siul2_Port_Ip_Cfg.o" "../board/Siul2_Port_Ip_Cfg.c"
Building file: ../board/dcd_config.c
make: *** [generate/src/subdir.mk:32: generate/src/Fls_Cfg.o] Error 1
make: *** [generate/src/subdir.mk:32: generate/src/Clock_Ip_Cfg.o] Error 1
make: *** [generate/src/subdir.mk:32: generate/src/Fls_VS_0_PBcfg.o] Error 1
make: *** [generate/src/subdir.mk:32: generate/src/OsIf_Cfg.o] Error 1
arm-none-eabi-gcc "@board/Siul2_Port_Ip_Cfg.args" -MMD -MP -MF"board/dcd_config.d" -MT"board/dcd_config.o" -o "board/dcd_config.o" "../board/dcd_config.c"
make: *** [generate/src/subdir.mk:32: generate/src/Qspi_Ip_VS_0_PBcfg.o] Error 1
make: *** [board/subdir.mk:29: board/Siul2_Port_Ip_Cfg.o] Error 1
make: *** [board/subdir.mk:29: board/dcd_config.o] Error 1
09:59:46 Build Failed. 9 errors, 0 warnings. (took 942ms)
18,232件の閲覧回数
VaneB
Hi @Chakradhar
The issue looks to be the Eevironment for lib path is not set. Set the environment for lib path as below example:
For Linux
export CC_LIB=<path to cross-compiler library>
export CC_LIB=/home/<username>/NXP/S32DS.3.4/S32DS/build_tools/gcc_v9.2/gcc-9.2-arm32-eabi/arm-none-eabi/newlib
For Windows
export CC_LIB=/C/nxp/S32DS.3.4/S32DS/build_tools/gcc_v9.2/gcc-9.2-arm32-eabi/arm-none-eabi/newlib
Choose the 32 bit or 64 bit tool-chain lib path as gcc-9.2-arm32-eabi OR gcc-9.2-arm64-eabi.
You can also see nano.specs file exists at location:
S32DS.3.4/S32DS/build_tools/gcc_v9.2/gcc-9.2-arm32-eabi/arm-none-eabi/newlib/lib/
Also, as I mentioned before the SAF85XX is not a mass-market device, I am not able to check or verify any information due to the security level when working with automotive parts such as this. Could you please contact the person that provided you with the device for further support on this part?
%3CLINGO-SUB%20id%3D%22lingo-sub-1695788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Earm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1695788%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AF%E3%80%81S32DS%20S32K3X2%E3%81%A7HSE_Demoapp%E3%82%92%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AB%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%B0%E3%81%8B%E5%8A%A9%E3%81%91%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20file%3A%20..%2FProject_Settings%2FStartup_Code%2FStartup.s%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%3CBR%20%2F%3EArm-none-eabi-gcc%20%22%40demo_app%2FStartup.args%22%20-o%20%22demo_app%2FStartup.o%22%20%22C%3A%2FTemp%2FNXP%2FHSE_DEMOAPP_S32K3X2_0_0_11_0%2Fdemo_security_installer%2Fsrc%2Fdemo_app%2Ftarget%2Fm7%2Fstartup%2FStartup.s%22%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40demo_app%2FVector_core.args%22-o%20%22demo_app%2FVector_core.o%22%22C%3A%2FTemp%2FNXP%2FHSE_DEMOAPP_S32K3X2_0_0_11_0%2Fdemo_security_installer%2Fsrc%2Fdemo_app%2Ftarget%2Fm7%2Fstartup%2FVector_core.s%22%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40Project_Settings%2FStartup_Code%2FStartup.args%22-o%20%22Project_Settings%2FStartup_Code%2FStartup.o%22%22..%2FProject_Settings%2FStartup_Code%2FStartup.s%22%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2FProject_Settings%2FStartup_Code%2FVector_core.s%3CBR%20%2F%3E%20%2Fbin%2Fsh%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5Bdemo_app%2Fsubdir.mk%3A19%3Ademo_app%2FStartup.o%5D%E3%82%A8%E3%83%A9%E3%83%BC127%3CBR%20%2F%3E%20make%3A%20***%20%E6%9C%AA%E5%AE%8C%E4%BA%86%E3%81%AE%E3%82%B8%E3%83%A7%E3%83%96%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD...%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%3CBR%20%2F%3E%2Fbin%2Fsh%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40Project_Settings%2FStartup_Code%2FStartup.args%22-o%20%22Project_Settings%2FStartup_Code%2FVector_core.o%22%22..%2FProject_Settings%2FStartup_Code%2FVector_core.s%22%3CBR%20%2F%3E%2Fbin%2Fsh%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5BProject_Settings%2FStartup_Code%2Fsubdir.mk%3A19%3AProject_Settings%2FStartup_Code%2FStartup.o%5D%E3%82%A8%E3%83%A9%E3%83%BC127%3CBR%20%2F%3E%20make%3A%20***%20%5Bdemo_app%2Fsubdir.mk%3A26%3Ademo_app%2FVector_core.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%20127%3CBR%20%2F%3E%20%2Fbin%2Fsh%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5BProject_Settings%2FStartup_Code%2Fsubdir.mk%3A19%3AProject_Settings%2FStartup_Code%2FVector_core.o%5D%E3%82%A8%E3%83%A9%E3%83%BC127%3CBR%20%2F%3E%20%E3%80%8Cmake%20-j12%20all%E3%80%8D%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%892%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2347302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2347302%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AECASE%E3%81%AF%E3%80%81Windows%2011%202026%20%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%9F%E7%92%B0%E5%A2%83%E5%A4%89%E6%95%B0%E3%81%AF%E3%80%81%E5%BD%93%E7%A4%BE%E3%81%AEIT%E9%83%A8%E9%96%80%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E6%A4%9C%E8%A8%BC%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3ECC_LIB%3D%3C%2FSPAN%3E%20C%3A%5CNXP%5CS32DS.3.6.4%5CS32DS%5Cbuild_tools%5Cgcc_v9.2%5Cgcc-9.2-arm32-eabi%5Carm-none-eabi%5Cnewlib%5Clib%5C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1866287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1866287%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%82%82RTD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9FDIO%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E5%90%8C%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E17%3A37%3A45%20****%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20Dio_Example_S32K144%20%E3%81%AE%E6%A7%8B%E6%88%90%20Debug_FLASH%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%20****%3CBR%20%2F%3E%20make%20-j12%20all%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FDio_Cfg.c%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FClock_Ip_VS_0_PBcfg.c%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FMcu_Cfg.c%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FClock_Ip_Cfg.c%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E4%B8%AD%3A%20..%2Fsrc%2Fmain.c%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FMcu_VS_0_PBcfg.c%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FClock_Ip_Cfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FDio_Cfg.d%22-MT%22generate%2Fsrc%2FDio_Cfg.o%22-o%20%22generate%2Fsrc%2FDio_Cfg.o%22%22..%2Fgenerate%2Fsrc%2FDio_Cfg.c%22%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40src%2Fmain.args%22-MMD%20-MP%20-MF%22src%2Fmain.d%22-MT%22src%2Fmain.o%22-o%20%22src%2Fmain.o%22%22..%2Fsrc%2Fmain.c%22%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FClock_Ip_Cfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FClock_Ip_Cfg.d%22-MT%22generate%2Fsrc%2FClock_Ip_Cfg.o%22-o%20%22generate%2Fsrc%2FClock_Ip_Cfg.o%22%22..%2Fgenerate%2Fsrc%2FClock_Ip_Cfg.c%22%3CBR%20%2F%3E%2Fbin%2Fsh%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%2Fbin%2Fsh%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5Bsrc%2Fsubdir.mk%3A20%3Asrc%2Fmain.o%5D%E3%82%A8%E3%83%A9%E3%83%BC127%3CBR%20%2F%3E%20make%3A%20***%20%E6%9C%AA%E5%AE%8C%E4%BA%86%E3%81%AE%E3%82%B8%E3%83%A7%E3%83%96%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD...%3CBR%20%2F%3E%20make%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A55%3A%20generate%2Fsrc%2FDio_Cfg.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%20127%3CBR%20%2F%3E%20%2Fbin%2Fsh%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FClock_Ip_Cfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FClock_Ip_VS_0_PBcfg.d%22-MT%22generate%2Fsrc%2FClock_Ip_VS_0_PBcfg.o%22-o%20%22generate%2Fsrc%2FClock_Ip_VS_0_PBcfg.o%22%22..%2Fgenerate%2Fsrc%2FClock_Ip_VS_0_PBcfg.c%22%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FClock_Ip_Cfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FMcu_VS_0_PBcfg.d%22-MT%22generate%2Fsrc%2FMcu_VS_0_PBcfg.o%22-o%20%22generate%2Fsrc%2FMcu_VS_0_PBcfg.o%22%22..%2Fgenerate%2Fsrc%2FMcu_VS_0_PBcfg.c%22%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FClock_Ip_Cfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FMcu_Cfg.d%22-MT%22generate%2Fsrc%2FMcu_Cfg.o%22-o%20%22generate%2Fsrc%2FMcu_Cfg.o%22%22..%2Fgenerate%2Fsrc%2FMcu_Cfg.c%22%3CBR%20%2F%3E%20make%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A56%3A%20generate%2Fsrc%2FClock_Ip_Cfg.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%20127%3CBR%20%2F%3E%20%2Fbin%2Fsh%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A56%3A%20generate%2Fsrc%2FClock_Ip_VS_0_PBcfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC127%3CBR%20%2F%3E%20%2Fbin%2Fsh%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A56%3A%20generate%2Fsrc%2FMcu_VS_0_PBcfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC127%3CBR%20%2F%3E%20%2Fbin%2Fsh%3A%20arm-none-eabi-gcc%3A%20%E3%82%B3%E3%83%9E%E3%83%B3%E3%83%89%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A56%3A%20generate%2Fsrc%2FMcu_Cfg.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%20127%3CBR%20%2F%3E%20%E3%80%8Cmake%20-j12%20all%E3%80%8D%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%892%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E17%3A37%3A46%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC13%E4%BB%B6%E3%80%81%E8%AD%A6%E5%91%8A0%E4%BB%B6%E3%80%82%EF%BC%88%E6%89%80%E8%A6%81%E6%99%82%E9%96%93%EF%BC%9A886%E3%83%9F%E3%83%AA%E7%A7%92%EF%BC%89%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1714224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1714224%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220913%22%20target%3D%22_blank%22%3E%40Chakradhar%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%81%94%E8%BF%B7%E6%83%91%E3%82%92%E3%81%8A%E3%81%8B%E3%81%91%E3%81%97%E3%81%A6%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%85%88%E3%81%BB%E3%81%A9%E7%94%B3%E3%81%97%E4%B8%8A%E3%81%92%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81%20%3CSPAN%3ESAF85XX%E3%81%AF%E9%87%8F%E7%94%A3%E5%93%81%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%8A%E5%AE%A2%E6%A7%98%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%E9%83%A8%E5%93%81%E3%82%92%E6%89%B1%E3%81%86%E5%A0%B4%E5%90%88%E3%80%81%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%83%AC%E3%83%99%E3%83%AB%E3%81%8C%E9%AB%98%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E6%83%85%E5%A0%B1%E3%81%AE%E7%A2%BA%E8%AA%8D%E3%82%84%E6%A4%9C%E8%A8%BC%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22ui-provider%20cby%20cbz%20c%20d%20e%20f%20g%20h%20i%20j%20k%20l%20m%20n%20o%20p%20q%20r%20s%20t%20cca%20ccb%20w%20x%20y%20z%20ab%20ac%20ae%20af%20ag%20ah%20ai%20aj%20ak%22%3E%E3%81%93%E3%81%AE%E4%BB%B6%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%95%E3%82%89%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%A9%9F%E5%99%A8%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%9F%E6%8B%85%E5%BD%93%E8%80%85%E3%81%AB%E9%80%A3%E7%B5%A1%E3%82%92%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1712785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1712785%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F201913%22%20target%3D%22_blank%22%3E%40VaneB%3C%2FA%3E%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%A8%E5%90%8C%E3%81%98%E6%89%8B%E9%A0%86%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%90%8C%E3%81%98%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%80%81%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%AB%E7%9B%B4%E9%9D%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20PATH%20%E5%A4%89%E6%95%B0%E3%81%AB%E4%BB%A5%E4%B8%8B%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20C%3A%5CTemp%5CNXP%5CS32DS.3.5%5Ceclipse%3BC%3A%5CTemp%5CNXP%5CS32DS.3.5%5CS32DS%5Cbuild_tools%5Cmsys32%5Cusr%5Cbin%3BC%3A%2FTemp%2FNXP%2FS32DS.3.5%2Feclipse%2Fjre%2Fbin%2Fclient%3BC%3A%2FTemp%2FNXP%2FS32DS.3.5%2Feclipse%2Fjre%2Fbin%3BC%3A%5Cwindows%5CSoftcamp%5CSDK%3BC%3A%5Cwindows%5CSoftcamp%5CSDS%5Cx64%3BC%3A%5Cwindows%5CSoftcamp%5CSDS%3BC%3A%5CProgramFiles%20(x86)%5CCommon%20Files%5COracle%5CJava%5Cjavapath%3BC%3A%5CProgram%20Files%5CWindchill%5CRVSClient12%5Cbin%3BC%3A%5CProgramData%5COracle%5CJava%5Cjavapath%3BC%3A%5CProgram%20Files%20(x86)%5CIqpad%5CubCENTRA%5C%3BC%3A%5Cwindows%5Csystem32%3BC%3A%5Cwindows%3BC%3A%5Cwindows%5CSystem32%5CWbem%3BC%3A%5Cwindows%5CSystem32%5CWindowsPowerShell%5Cv1.0%5C%3BC%3A%5Cwindows%5CSystem32%5COpenSSH%5C%3BC%3A%5CProgramFiles%5CBandizip%5C%3BC%3A%5CProgram%20Files%5CPuTTY%5C%3BC%3A%5CProgram%20Files%20(x86)%5CVector%20CANdb%2B%2B%203.1%5CExec32%3BC%3A%5CProgram%20Files%5Cdotnet%5C%3BC%3A%5CProgram%20Files%20(x86)%5Cdotnet%5C%3BC%3A%5CPROGRA~1%5CWINDCH~1%5CToolkit%5Cmksnt%3BC%3A%5CProgram%20Files%5CTortoiseGit%5Cbin%3BC%3A%5CProgram%20Files%5CGit%5Ccmd%3BC%3A%5CProgram%20Files%5CCMake%5Cbin%3BC%3A%5CProgram%20Files%5CPolyspace%5CR2022b%5Cpolyspace%5Cbin%3BC%3A%5CUsers%5Cmobis%5CAppData%5CLocal%5CPrograms%5CPython%5CPython311%5CScripts%5C%3BC%3A%5CUsers%5Cmobis%5CAppData%5CLocal%5CPrograms%5CPython%5CPython311%5C%3BC%3A%5CUsers%5Cmobis%5CAppData%5CLocal%5CMicrosoft%5CWindowsApps%3BC%3A%5CProgram%20Files%5CGit%5Ccmd%3BC%3A%5CProgram%20Files%5CTortoiseGit%5Cbin%3BC%3A%5CTemp%5Cbin%3BC%3A%5CTemp%5CNXP%5CS32DS.3.5%5CS32DS%5Ctools%5Cgdb-arm%5Carm32-eabi%5Cbin%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1708558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1708558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220913%22%20target%3D%22_blank%22%3E%40Chakradhar%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%95%8F%E9%A1%8C%E3%81%AF%E3%80%81%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%83%91%E3%82%B9%E3%81%AE%E7%92%B0%E5%A2%83%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E3%81%93%E3%81%A8%E3%81%AE%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%83%91%E3%82%B9%E3%81%AE%E7%92%B0%E5%A2%83%E8%A8%AD%E5%AE%9A%E3%82%92%E4%BB%A5%E4%B8%8B%E3%81%AE%E4%BE%8B%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A1%8C%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3ELinux%E5%90%91%E3%81%91%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3Eexport%20CC_LIB%3D%3CPATH%20to%3D%22%22%20cross-compiler%3D%22%22%20library%3D%22%22%3E%3C%2FPATH%3E%3C%2FP%3E%0A%3CP%3Eexport%20CC_LIB%3D%2Fhome%2F%3CUSERNAME%3E%2FNXP%2FS32DS.3.4%2FS32DS%2Fbuild_tools%2Fgcc_v9.2%2Fgcc-9.2-arm32-eabi%2Farm-none-eabi%2Fnewlib%3C%2FUSERNAME%3E%3C%2FP%3E%0A%3CP%3E%3CSTRONG%3EWindows%E7%94%A8%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3Eexport%20CC_LIB%3D%3CPATH%20to%3D%22%22%20cross-compiler%3D%22%22%20library%3D%22%22%3E%3C%2FPATH%3E%3C%2FP%3E%0A%3CP%3Eexport%20CC_LIB%3D%2FC%2Fnxp%2FS32DS.3.4%2FS32DS%2Fbuild_tools%2Fgcc_v9.2%2Fgcc-9.2-arm32-eabi%2Farm-none-eabi%2Fnewlib%3C%2FP%3E%0A%3CP%3E32%E3%83%93%E3%83%83%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF64%E3%83%93%E3%83%83%E3%83%88%E3%81%AE%E3%83%84%E3%83%BC%E3%83%AB%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%96%E3%83%A9%E3%83%AA%E3%83%91%E3%82%B9%E3%81%A8%E3%81%97%E3%81%A6gcc-9.2-arm32-eabi%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%BE%E3%81%9F%E3%81%AF%20gcc-9.2-arm64-eabi%E3%80%82%3C%2FP%3E%0A%3CP%3Enano.specs%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3ES32DS.3.4%2FS32DS%2Fbuild_tools%2Fgcc_v9.2%2Fgcc-9.2-arm32-eabi%2Farm-none-eabi%2Fnewlib%2Flib%2F%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E5%85%88%E3%81%AB%E3%82%82%E8%BF%B0%E3%81%B9%E3%81%9F%E3%82%88%E3%81%86%E3%81%AB%E3%80%81SAF85XX%E3%81%AFMass%20Market%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%E9%83%A8%E5%93%81%E3%82%92%E6%89%B1%E3%81%86%E9%9A%9B%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E9%AB%98%E3%81%95%E3%81%8B%E3%82%89%E3%80%81%E6%83%85%E5%A0%B1%E3%81%AE%E7%A2%BA%E8%AA%8D%E3%82%84%E6%A4%9C%E8%A8%BC%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%81%AE%E4%BB%B6%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%95%E3%82%89%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%A9%9F%E5%99%A8%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%9F%E6%8B%85%E5%BD%93%E8%80%85%E3%81%AB%E9%80%A3%E7%B5%A1%E3%82%92%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1707974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1707974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F201913%22%20target%3D%22_blank%22%3E%40VaneB%20%E3%81%95%E3%82%93%E3%80%81%3C%2FA%3E%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%87%BA%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3ES32%20Design%20Studio%E3%81%A7%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%80%8CHSE_DEMOAPP_SAF85xx_1_0_23_2%E3%80%8D%E3%82%92%E6%A7%8B%E7%AF%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E5%95%8F%E9%A1%8C%EF%BC%9A%3C%2FP%3E%3CP%3E****%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20HSE_DEMO_SAF85XX%20%E3%81%AE%E6%A7%8B%E6%88%90%20BuildConfig_Flash%20%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%20****%3CBR%20%2F%3E%20make%20-j12%20all%3CBR%20%2F%3E%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E4%B8%AD%3A%20..%2Fsrc%2Fsys_init.c%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FClock_Ip_Cfg.c%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40src%2Fsys_init.args%22%20-MMD%20-MP%20-MF%22src%2Fsys_init.d%22-MT%22src%2Fsys_init.o%22-o%20%22src%2Fsys_init.o%22%22..%2Fsrc%2Fsys_init.c%22%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FFls_Cfg.c%3CBR%20%2F%3E%20arm-none-eabi-gcc%20%22%40generate%2Fsrc%2FClock_Ip_Cfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FClock_Ip_Cfg.d%22-MT%22generate%2Fsrc%2FClock_Ip_Cfg.o%22-o%20%22generate%2Fsrc%2FClock_Ip_Cfg.o%22%22..%2Fgenerate%2Fsrc%2FClock_Ip_Cfg.c%22%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FClock_Ip_Cfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FFls_Cfg.d%22-MT%22generate%2Fsrc%2FFls_Cfg.o%22-o%20%22generate%2Fsrc%2FFls_Cfg.o%22%22..%2Fgenerate%2Fsrc%2FFls_Cfg.c%22%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FFls_VS_0_PBcfg.c%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FClock_Ip_Cfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FFls_VS_0_PBcfg.d%22-MT%22generate%2Fsrc%2FFls_VS_0_PBcfg.o%22-o%20%22generate%2Fsrc%2FFls_VS_0_PBcfg.o%22%22..%2Fgenerate%2Fsrc%2FFls_VS_0_PBcfg.c%22%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FOsIf_Cfg.c%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FClock_Ip_Cfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FOsIf_Cfg.d%22-MT%22generate%2Fsrc%2FOsIf_Cfg.o%22-o%20%22generate%2Fsrc%2FOsIf_Cfg.o%22%22..%2Fgenerate%2Fsrc%2FOsIf_Cfg.c%22%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FQspi_Ip_VS_0_PBcfg.c%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FClock_Ip_Cfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FQspi_Ip_VS_0_PBcfg.d%22-MT%22generate%2Fsrc%2FQspi_Ip_VS_0_PBcfg.o%22-o%20%22generate%2Fsrc%2FQspi_Ip_VS_0_PBcfg.o%22%22..%2Fgenerate%2Fsrc%2FQspi_Ip_VS_0_PBcfg.c%22%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fboard%2FSiul2_Port_Ip_Cfg.c%3CBR%20%2F%3E%E5%86%85%E8%94%B5%E4%BB%95%E6%A7%98%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Enano.specs%E3%81%8B%E3%82%89%E4%BB%95%E6%A7%98%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3CBR%20%2F%3Earm-none-eabi-gcc.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20nano.specs%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E5%86%85%E8%94%B5%E4%BB%95%E6%A7%98%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Enano.specs%E3%81%8B%E3%82%89%E4%BB%95%E6%A7%98%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3CBR%20%2F%3Earm-none-eabi-gcc.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20nano.specs%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E5%86%85%E8%94%B5%E4%BB%95%E6%A7%98%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Enano.specs%E3%81%8B%E3%82%89%E4%BB%95%E6%A7%98%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3CBR%20%2F%3Earm-none-eabi-gcc.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20nano.specs%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E5%86%85%E8%94%B5%E4%BB%95%E6%A7%98%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Enano.specs%E3%81%8B%E3%82%89%E4%BB%95%E6%A7%98%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3CBR%20%2F%3Earm-none-eabi-gcc.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20nano.specs%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Emake%3A%20***%20%5Bsrc%2Fsubdir.mk%3A20%3Asrc%2Fsys_init.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20arm-none-eabi-gcc%20%22%40board%2FSiul2_Port_Ip_Cfg.args%22-MMD%20-MP%20-MF%22board%2FSiul2_Port_Ip_Cfg.d%22-MT%22board%2FSiul2_Port_Ip_Cfg.o%22-o%20%22board%2FSiul2_Port_Ip_Cfg.o%22%22..%2Fboard%2FSiul2_Port_Ip_Cfg.c%22%3CBR%20%2F%3E%20make%3A%20***%20%E6%9C%AA%E5%AE%8C%E4%BA%86%E3%81%AE%E3%82%B8%E3%83%A7%E3%83%96%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD...%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fboard%2Fdcd_config.c%3CBR%20%2F%3E%20make%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A32%3A%20generate%2Fsrc%2FFls_Cfg.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%3CBR%20%2F%3E%E5%86%85%E8%94%B5%E4%BB%95%E6%A7%98%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Enano.specs%E3%81%8B%E3%82%89%E4%BB%95%E6%A7%98%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3CBR%20%2F%3Earm-none-eabi-gcc.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20nano.specs%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A32%3A%20generate%2Fsrc%2FClock_Ip_Cfg.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%3CBR%20%2F%3E%20make%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A32%3A%20generate%2Fsrc%2FFls_VS_0_PBcfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20make%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A32%3A%20generate%2Fsrc%2FOsIf_Cfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40board%2FSiul2_Port_Ip_Cfg.args%22-MMD%20-MP%20-MF%22board%2Fdcd_config.d%22%20-MT%22board%2Fdcd_config.o%22%20-o%20%22board%2Fdcd_config.o%22%20%22..%2Fboard%2Fdcd_config.c%22%3CBR%20%2F%3E%E5%86%85%E8%94%B5%E4%BB%95%E6%A7%98%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Enano.specs%E3%81%8B%E3%82%89%E4%BB%95%E6%A7%98%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3CBR%20%2F%3Earm-none-eabi-gcc.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20nano.specs%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A32%3A%20generate%2Fsrc%2FQspi_Ip_VS_0_PBcfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%E5%86%85%E8%94%B5%E4%BB%95%E6%A7%98%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Enano.specs%E3%81%8B%E3%82%89%E4%BB%95%E6%A7%98%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3CBR%20%2F%3Earm-none-eabi-gcc.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20nano.specs%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3Aboard%2FSiul2_Port_Ip_Cfg.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%3CBR%20%2F%3E%E5%86%85%E8%94%B5%E4%BB%95%E6%A7%98%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3Enano.specs%E3%81%8B%E3%82%89%E4%BB%95%E6%A7%98%E3%82%92%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%82%80%3CBR%20%2F%3Earm-none-eabi-gcc.exe%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20nano.specs%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3Emake%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3Aboard%2Fdcd_config.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20%E3%80%8Cmake%20-j12%20all%E3%80%8D%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%892%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E09%3A59%3A46%20%E3%83%93%E3%83%AB%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A8%E3%83%A9%E3%83%BC9%E4%BB%B6%E3%80%81%E8%AD%A6%E5%91%8A0%E4%BB%B6%E3%80%82%EF%BC%88%E6%89%80%E8%A6%81%E6%99%82%E9%96%93%EF%BC%9A942%E3%83%9F%E3%83%AA%E7%A7%92%EF%BC%89%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1706886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1706886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220913%22%20target%3D%22_blank%22%3E%40Chakradhar%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EIDE%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%AE%E3%81%A7%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AFHSE_DEMOAPP_S32K311_0_2_14_0%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%81%8C%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82S32K3%E6%8B%A1%E5%BC%B5%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%82%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1705789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1705789%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3CP%3ES32%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%81%AE%E8%A9%B3%E7%B4%B0%3C%2FP%3E%3CP%3ES32%E3%83%97%E3%83%A9%E3%83%83%E3%83%88%E3%83%95%E3%82%A9%E3%83%BC%E3%83%A0%E5%90%91%E3%81%91S32%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%82%B9%E3%82%BF%E3%82%B8%E3%82%AA%3CBR%20%2F%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%203.5%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89ID%3A%20220726%3C%2FP%3E%3CP%3E%E8%91%97%E4%BD%9C%E6%A8%A9%202017-2022%20NXP%3C%2FP%3E%3CP%3E%3CA%20href%3D%22http%3A%2F%2Fwww.nxp.com%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttp%3A%2F%2Fwww.nxp.com%2F%3C%2FA%3E%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E6%9C%AC%E8%A3%BD%E5%93%81%E3%81%AB%E3%81%AF%E3%80%81Eclipse%20Foundation%20%3CA%20href%3D%22http%3A%2F%2Fwww.eclipse.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%88http%3A%2F%2Fwww.eclipse.org%2F%3C%2FA%3E%20%EF%BC%89%E3%81%8C%E9%96%8B%E7%99%BA%E3%81%97%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%AC%E8%A3%BD%E5%93%81%E3%81%AB%E3%81%AF%E3%80%81Apache%20Software%20Foundation%20%3CA%20href%3D%22http%3A%2F%2Fapache.org%2F%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E%EF%BC%88http%3A%2F%2Fapache.org%2F%EF%BC%89%3C%2FA%3E%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E9%96%8B%E7%99%BA%E3%81%95%E3%82%8C%E3%81%9F%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8C%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1700386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1700386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220913%22%20target%3D%22_blank%22%3E%40Chakradhar%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E9%80%9A%E5%B8%B8%E3%80%81%E3%81%93%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AFHSE%20FW%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E6%99%82%E3%81%AE%E3%83%93%E3%83%AB%E3%83%89%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E5%8E%9F%E5%9B%A0%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%8A%E4%BD%BF%E3%81%84%E3%81%AEIDE%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%9F%E3%81%84%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%82%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AF%E4%BD%9C%E6%88%90%E6%99%82%E7%82%B9%E3%81%A7%E3%81%AFS32DS%20v3.5%E5%90%91%E3%81%91%E3%81%AB%E4%BD%9C%E6%88%90%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%98%E3%83%AB%E3%83%97%E2%86%92S32%20Design%20Studio%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%82%92%E3%81%94%E7%A2%BA%E8%AA%8D%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81S32K3%E6%8B%A1%E5%BC%B5%E3%83%91%E3%83%83%E3%82%B1%E3%83%BC%E3%82%B8%E3%82%82%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1699903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1699903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F201913%22%20target%3D%22_blank%22%3E%40VaneB%3C%2FA%3E%20arm-none-eabi-gcc%3A%20command%20not%20found%20%E3%81%AE%E8%A7%A3%E6%B1%BA%E6%96%B9%E6%B3%95%E3%82%92%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1698884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1698884%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220913%22%20target%3D%22_blank%22%3E%40Chakradhar%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%A7%81%E3%81%AE%E7%90%86%E8%A7%A3%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%82%89%E8%A8%82%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3ESAF85XX%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AB%E3%81%AFHSE%20B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%8E%A8%E5%A5%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81HSE%20B%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81SAF85XX%E3%81%AFMass%20Market%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%9F%E3%82%81%E3%80%81%E3%81%93%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%82%AA%E3%83%BC%E3%83%88%E3%83%A2%E3%83%BC%E3%83%86%E3%82%A3%E3%83%96%E9%83%A8%E5%93%81%E3%82%92%E6%89%B1%E3%81%86%E9%9A%9B%E3%81%AE%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E3%83%AC%E3%83%99%E3%83%AB%E3%81%AE%E9%AB%98%E3%81%95%E3%81%8B%E3%82%89%E3%80%81%E6%83%85%E5%A0%B1%E3%81%AE%E7%A2%BA%E8%AA%8D%E3%82%84%E6%A4%9C%E8%A8%BC%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3CSPAN%3E%3CSPAN%20class%3D%22ui-provider%20cby%20cbz%20c%20d%20e%20f%20g%20h%20i%20j%20k%20l%20m%20n%20o%20p%20q%20r%20s%20t%20cca%20ccb%20w%20x%20y%20z%20ab%20ac%20ae%20af%20ag%20ah%20ai%20aj%20ak%22%3E%E3%81%93%E3%81%AE%E4%BB%B6%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%81%95%E3%82%89%E3%81%AB%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AA%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%A9%9F%E5%99%A8%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%8F%E3%82%8C%E3%81%9F%E6%8B%85%E5%BD%93%E8%80%85%E3%81%AB%E9%80%A3%E7%B5%A1%E3%82%92%E5%8F%96%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1697154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1697154%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F201913%22%20target%3D%22_blank%22%3E%40VaneB%3C%2FA%3E%E7%A7%81%E3%81%AFreadme%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%80%81%E6%9C%80%E6%96%B0%E3%83%95%E3%82%A1%E3%82%A4%E3%83%ABHSE_DEMOAPP_S32K311_0_2_14_0%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20'C%3A%2FTemp%2FNXP%2FHSE_DEMOAPP_S32K311_0_2_14_0%2Fdemo_security_installer%2Fsrc%2Fdemo_app%2Ftarget%2Fm7%2Fsrc%2Fsys_init.c'%20%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%83%AB%E3%83%BC%E3%83%AB%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82'demo_app%2Ftarget%2Fm7%2Fsrc%2Fsys_init.o'%20%E3%81%A7%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AFSAF85XX%E8%A3%BD%E5%93%81%EF%BC%88HSE_M%EF%BC%88%E4%B8%AD%EF%BC%89%E3%81%AF%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AC%E3%82%B9S32x%E8%A3%BD%E5%93%81%E3%83%90%E3%83%AA%E3%82%A2%E3%83%B3%E3%83%88%EF%BC%88S32R41%E3%82%84SAF85%E3%81%AA%E3%81%A9%EF%BC%89%E3%81%A7%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%EF%BC%89%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%8A%E3%82%8A%E3%80%81%E3%81%93%E3%82%8C%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%99%3C%2FP%3E%3CP%3EGHS%E3%81%A7demo_app_m7_0.gpj%EF%BC%88HSE_B%E3%81%AF%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%EF%BC%89%E3%82%92%E9%96%8B%E3%81%93%E3%81%86%E3%81%A8%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%3CBR%20%2F%3E%E3%80%8C%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3A%20arm_standalone.tgt%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1696929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20arm-none-eabi-gcc%3A%20command%20not%20found%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1696929%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F220913%22%20target%3D%22_blank%22%3E%40Chakradhar%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%81%9F%E6%83%85%E5%A0%B1%E3%81%8B%E3%82%89%E5%88%A4%E6%96%AD%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81S32K312%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%A8%E4%BA%92%E6%8F%9B%E6%80%A7%E3%81%AE%E3%81%82%E3%82%8B%20HSE%20%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E6%A8%99%E6%BA%96%20EAR%20%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%20(s32k3x2_hse_fw_0.13.0_0.11.0_pb210726.bin%20(FullMem)%20%E3%81%8A%E3%82%88%E3%81%B3%20s32k3x2_hse_fw_1.13.0_0.11.0_pb210726.bin%20(AB%20Swap))%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%82%E3%81%AE%E3%81%A8%E6%8E%A8%E6%B8%AC%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%B8%B8%E3%81%AB%E6%9C%80%E6%96%B0%E7%89%88%E3%81%AE%E3%81%94%E5%88%A9%E7%94%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%81%AB%E9%96%A2%E3%81%99%E3%82%8B%E5%95%8F%E9%A1%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AE%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A8%E3%83%93%E3%83%AB%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%E3%82%92%E8%A1%8C%E3%81%86%E9%9A%9B%E3%81%AB%E3%80%81Read%20Me%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%9F%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EVaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E
