about install S32 DS 3.6.0
3,095 次查看
yaozhong_zhu
When installing S32 Design Studio 3.6.0, I entered an incorrect Activation Code. Now, when I try to reinstall it, the Activation Code input screen no longer appears, and the installation rolls back. How can I resolve this?
3,056 次查看
yaozhong_zhu
I realized the issue was likely due to insufficient space on Drive C. During the unzipping process, I had selected Drive D, which caused a command execution error. After increasing the free space on Drive C, the problem was resolved.
D:\ecu\S32K1X\I1741740730\Windows>cd "C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86"
D:\ecu\S32K1X\I1741740730\Windows>cllSvrUtility.exe -installService LAXCompiler
3,043 次查看
yaozhong_zhu
are you starting S32DS installer with admin rights?  --- yes
install log:
__________________________________________________________________________
Wed Mar 12 08:55:29 CST 2025
Free Memory: 240035 kB
Total Memory: 262144 kB
java.class.path:
D:\ecu\S32K1X\I1741740730\InstallerData\IAClasses.zip
D:\ecu\S32K1X\I1741740730\InstallerData\Execute.zip
D:\ecu\S32K1X\I1741740730\Windows\InstallerData\Execute.zip
D:\ecu\S32K1X\I1741740730\InstallerData\Resource1.zip
D:\ecu\S32K1X\I1741740730\Windows\InstallerData\Resource1.zip
ZGUtil.CLASS_PATH:
sun.boot.class.path:
<none specified>
java.ext.dirs:
<none specified>
java.version == 17.0.9 (Java 1)
java.vm.name == OpenJDK 64-Bit Server VM
java.vm.vendor == Eclipse Adoptium
java.vm.version == 17.0.9+9
java.vm.specification.name == Java Virtual Machine Specification
java.vm.specification.vendor == Oracle Corporation
java.vm.specification.version == 17
java.specification.name == Java Platform API Specification
java.specification.vendor == Oracle Corporation
java.specification.version == 17
java.vendor == Eclipse Adoptium
java.vendor.url == https://adoptium.net/
java.class.version == 61.0
java.library.path == D:\ecu\S32K1X\I1741740730\Windows\resource\jre\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;E:\NXP\S32DS_ARM_v2.2\S32DS\build_tools\gcc_v4.9\gcc-arm-none-eabi-4_9\bin;E:\NXP\S32DS_ARM_v2.2\S32DS\build_tools\msys32\mingw32\bin;C:\Program Files\Common Files\Oracle\Java\javapath;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\ProgramData\Oracle\Java\javapath_;C:\Program Files (x86)\STMicroelectronics\st_toolset\asm;C:\Perl\bin;C:\Perl\site\bin;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\ARM\Utilities\FLEXlm\10.8.5.0\1\win_32-pentium;C:\ARM\RVCT\Programs\3.1\569\win_32-pentium;C:\ARM\RDI\Deprecated\1.3.1\1\windows;C:\ARM\bin\win_32-pentium;C:\WINDOWS\System32\OpenSSH\;C:\Qt\Qt5.11.2\5.11.2\msvc2017_64\bin;C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\VC\Tools\MSVC\14.15.26726\bin\Hostx64\x64;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\MinGW\msys\1.0\bin;C:\Program Files\Java\jre1.8.0_45\bin;C:\Users\yaozhong\AppData\Local\Programs\Python\Python39\Scripts;C:\Users\yaozhong\AppData\Local\Programs\Python\Python39;C:\Program Files (x86)\Windows Kits\10\Windows Performance Toolkit\;C:\Program Files (x86)\Freescale\CWS12v5.1\bin;E:\Program Files (x86)\Prince\engine\bin;E:\Program Files\CMake\bin;E:\Ninja;E:\Program Files\nodejs\;C:\Program Files\Git\cmd;C:\Program Files\dotnet\;D:\IEM\NucleiStudio\toolchain\openocd\bin;D:\IEM\NucleiStudio\toolchain\gcc\libexec\gcc\riscv-nuclei-elf\10.2.0;E:\Program Files\Tesseract-OCR;E:\python38\Scripts\;E:\python38\;C:\Program Files (x86)\Microsoft Visual Studio\Common\Tools\WinNT;C:\Program Files (x86)\Microsoft Visual Studio\Common\MSDev98\Bin;C:\Program Files (x86)\Microsoft Visual Studio\Common\Tools;C:\Program Files (x86)\Microsoft Visual Studio\VC98\bin;C:\Users\yaozhong\AppData\Local\Microsoft\WindowsApps;C:\Program Files (x86)\SSH Communications Security\SSH Secure Shell;C:\MinGW\bin;c:\JL\commtools;c:\JL\dv10\bin;c:\JL\dv12\bin;c:\JL\mc\bin;c:\JL\pi32\bin;C:\Users\yaozhong\.dotnet\tools;F:\LenovoSoftstore\Install\QQliuxidating\QQGameTempest\Hall.57808\;C:\Users\yaozhong\AppData\Roaming\npm;e:\vscode\bin;C:\Users\yaozhong\AppData\Local\Programs\Ollama;.
java.compiler == null
java.home == D:\ecu\S32K1X\I1741740730\Windows\resource\jre
java.io.tmpdir == C:\Users\yaozhong\AppData\Local\Temp\
os.name == Windows 10
os.arch == amd64
os.version == 10.0
path.separator == ;
file.separator == \
file.encoding == GBK
user.name == hellodog
user.home == C:\Users\yaozhong
user.dir == D:\ecu\S32K1X\I1741740730\Windows
user.language == en
user.region == null
Installed Feature(s) S32DSF of S32 Design Studio for S32 Platform 3.6.0
Install Begin: MARCH 12, 2025 8:54:33 AM CST
Install End: MARCH 12, 2025 8:55:26 AM CST
Installed by InstallAnywhere 24.0 Premier Build 7020
User Interactions
#Choose Install Location
USER_INSTALL_DIR=d:\\NXP\\S32DS.3.6.0
#Choose Shortcut Folder
USER_SHORTCUTS=C:\\Users\\yaozhong\\AppData\\Roaming\\Microsoft\\Windows\\Start Menu\\Programs\\NXP S32 Design Studio\\S32 Design Studio for S32 Platform 3.6.0
#Install
-fileOverwrite_d\:\\NXP\\S32DS.3.6.0\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.6.0_installation\\resource\\iawin64_x64.dll=Yes
-fileOverwrite_d\:\\NXP\\S32DS.3.6.0\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.6.0_installation\\resource\\iawin32.dll=Yes
-fileOverwrite_d\:\\NXP\\S32DS.3.6.0\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.6.0_installation\\resource\\win64_32_x64.exe=Yes
-fileOverwrite_d\:\\NXP\\S32DS.3.6.0\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.6.0_installation\\resource\\remove.exe=Yes
-fileOverwrite_d\:\\NXP\\S32DS.3.6.0\\_S32\ Design\ Studio\ for\ S32\ Platform\ 3.6.0_installation\\resource\\invoker.exe=Yes
Summary
Installation: Unsuccessful.
78 Successes
4 Warnings
1 NonFatalErrors
1 FatalErrors
Action Notes:
None
Install Log Detail:
Check Disk Space: d:\NXP\S32DS.3.6.0
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space:4,838,542,629 Bytes Free Disk Space:50,705,395,712 Bytes
Check Disk Space: C:\NXP\S32DS.3.6.0
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space:12,838,542,629 Bytes Free Disk Space:8,727,138,304 Bytes
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space:12,838,542,629 Bytes Free Disk Space:50,705,391,616 Bytes
Status: SUCCESSFUL
Additional Notes: NOTE - Required Disk Space:12,838,542,629 Bytes Free Disk Space:50,705,387,520 Bytes
Install Directory: d:\NXP\S32DS.3.6.0\jre
Status: SUCCESSFUL
Install JRE: d:\NXP\S32DS.3.6.0\jre
Status: SUCCESSFUL
Install Directory: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\
Status: SUCCESSFUL
Additional Notes: NOTE - Directory already existed
Execute Command: NET SESSION
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist_2013_x86.exe
Status: SUCCESSFUL
Expand Archive: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist32.zip
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist_2013_x64.exe
Status: SUCCESSFUL
Expand Archive: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist64.zip
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist_2022_x64.exe
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\check_vs_x64.bat
Status: SUCCESSFUL
Expand Archive: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist_2022_x64.zip
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist_2022_x86.exe
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\check_vs_x86.bat
Status: SUCCESSFUL
Expand Archive: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist_2022_x86.zip
Status: SUCCESSFUL
Execute Command: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist_2013_x86.exe /quiet
Status: SUCCESSFUL
Execute Command: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist_2013_x64.exe /quiet
Status: SUCCESSFUL
Execute Command: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist_2022_x64.exe /quiet /norestart
Status: SUCCESSFUL
Execute Command: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\vcredist_2022_x86.exe /quiet /norestart
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86\clljni.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86\cllSvrUtility.exe
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86\cllSvrUtility.exe.manifest
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86\cll_app.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86\cll_app_libFNP.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86\cll_svr.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86\cll_svr_libFNP.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86\FnpCommsSoap.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86\FNP_Act_Installer.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\clljni.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\cll_app.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\cll_app_libFNP.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\cll_svr.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\cll_svr_libFNP.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\FnpCommsSoap.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\FnpCommsSoap.so
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\FNP_Act_Installer.dll
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\libclljni.so
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\libcll_app.so
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\libcll_app_libFNP.so
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\libcll_svr.so
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64\libcll_svr_libFNP.so
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\FNPLicensingService\FNPLicensingService
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\install_fnp.sh
Status: SUCCESSFUL
Install File: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\license.jar
Status: SUCCESSFUL
Expand Archive: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\Activation.zip
Status: SUCCESSFUL
Execute Command: d:\NXP\S32DS.3.6.0\jre\bin\java.exe "-Djava.library.path=C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64" -jar "C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\license.jar" install -prod SW32_S32DS_3.6
Status: SUCCESSFUL
Execute Command: d:\NXP\S32DS.3.6.0\jre\bin\java.exe "-Djava.library.path=C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64" -jar "C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\license.jar" verify -feature Activated -version 3.6 -prod SW32_S32DS_3.6
Status: SUCCESSFUL
Execute Command: d:\NXP\S32DS.3.6.0\jre\bin\java.exe "-Djava.library.path=C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64" -jar "C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\license.jar" list
Status: SUCCESSFUL
Execute Command: d:\NXP\S32DS.3.6.0\jre\bin\java.exe "-Djava.library.path=C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64" -jar "C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\license.jar" printFlexVersion
Status: SUCCESSFUL
Execute Script/Batch file: Install 32-bit Flexera service
Status: SUCCESSFUL
Install Uninstaller: S32 Design Studio for S32 Platform 3.6.0(Install All Uninstaller Components)
Status: SUCCESSFUL
Install Directory: d:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\resource\
Status: SUCCESSFUL
Install File: d:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\resource\iawin64_x64.dll
Status: SUCCESSFUL
Install File: d:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\resource\iawin32.dll
Status: SUCCESSFUL
Install File: d:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\resource\win64_32_x64.exe
Status: SUCCESSFUL
Install File: d:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\resource\remove.exe
Status: SUCCESSFUL
Install File: d:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\resource\invoker.exe
Status: SUCCESSFUL
Make Registry Entry: Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\S32 Design Studio for S32 Platform 3.6.0
Value Name: EstimatedSize
Value Data: bf5f7d
Status: SUCCESSFUL
Status: ERROR
Additional Notes: ERROR - Error writing LaunchAnywhere components (Access Denied)
Execute Script/Batch file: Uninstalling Design Studio files
Status: SUCCESSFUL
Uninstall Folder: d:\NXP\S32DS.3.6.0\jre
Status: SUCCESSFUL
Status: SUCCESSFUL
Uninstall Folder: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\FNPLicensingService
Status: WARNING
Additional Notes: WARNING - The path does not exist
Uninstall Folder: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\x64
Status: WARNING
Uninstall Folder: C:\Users\yaozhong\AppData\Local\Temp\127426.tmp\cll\i86
Status: WARNING
Status: WARNING
Delete File: Source:s32ds.bat
Status: SUCCESSFUL
Additional Notes: NOTE - Source file s32ds.bat does not exist.
Status: SUCCESSFUL
Delete File: Source:Welcome.txt
Status: SUCCESSFUL
Additional Notes: NOTE - Source file Welcome.txt does not exist.
Remove Registry Entry: 5 HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\null
Status: SUCCESSFUL
Error occurred while installing the following Action, hence rolling back the installation....!
Action Name: Trigger Rollback Action
Action Description: Trigger Rollback Action
Error Details as below:
This action rolls back the Installation.
====================STDERR ENTRIES==================
InstallAnywhere 2024
Version: 24.0
Wed Mar 12 08:54:31 CST 2025
Free Memory: 246863 kB
No Arguments
java.class.path:
ZGUtil.CLASS_PATH:
<none specified>
java.ext.dirs:
<none specified>
os.arch == amd64
os.version == 10.0
path.separator == ;
file.separator == \
user.language == zh
user.region == null
Loading externalized properties
RepositoryManager: Trying fallback repository location...
==== Installer properties log start: ====
User Install directory: d:\NXP\S32DS.3.6.0
User Shortcuts: C:\Users\yaozhong\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\NXP S32 Design Studio\S32 Design Studio for S32 Platform 3.6.0
==== Installer properties log end. ====
# INSTALLING VM: d:\NXP\S32DS.3.6.0\jre
System's temporary directory = C:\Users\yaozhong\AppData\Local\Temp
==== NET SESSION command log start: ====
Returned: 0
Console: 列表是空的。
Errors:
==== NET SESSION command log end. ====
==== License service installation log start: ====
Console: Found C:\\Program Files (x86)\\Common Files\\Macrovision Shared\\FlexNet Publisher\\FNPLicensingService.exe
Version
11.16.0.0
Found C:\\Program Files\\Common Files\\Macrovision Shared\\FlexNet Publisher\\FNPLicensingService64.exe
Version
11.18.2.0
Errors:
==== License service installation log end. ====
==== License activation log start: ====
Console:
Errors:
==== License activation log end. ====
==== License list start: ====
Console: CLLFeatureDetail [productName=SW32_S32DS_3.6, featureName=APUCompiler, featureVersion=2.0, activationID=1EE4-731B-AFD0-81FE, expirationDate=10-Mar-2029, daysToExpire=1459, description=, location=CLL_LOCATION_TYPE_FNO, hasNext=true]
CLLFeatureDetail [productName=SW32_S32DS_3.6, featureName=Activated, featureVersion=3.6, activationID=1EE4-731B-AFD0-81FE, expirationDate=10-Mar-2029, daysToExpire=1459, description=, location=CLL_LOCATION_TYPE_FNO, hasNext=true]
CLLFeatureDetail [productName=SW32_S32DS_3.6, featureName=LAXCompiler, featureVersion=2.0, activationID=1EE4-731B-AFD0-81FE, expirationDate=10-Mar-2029, daysToExpire=1459, description=, location=CLL_LOCATION_TYPE_FNO, hasNext=false]
Errors:
==== License list end. ====
==== FNP library version log start: ====
Console: PrintFlexVersion.execute()
**********from printFlexVersion()***********
major: 11 minor: 18 beta: 0 build: 281478 str: v11.18.2.0 build 281478 x64_n6
Errors:
==== FNP library version log end. ====
==== 32-bit license service installation log start: ====
Returned: 1
Console:
Errors: 'cllSvrUtility.exe' 不是内部或外部命令,也不是可运行的程序
或批处理文件。
==== 32-bit license service installation log end. ====
XMLScriptWriter: No Installation Objects were skipped
8. final log file name=d:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\Logs\S32_Design_Studio_for_S32_Platform_3.6.0_Install_03_12_2025_08_55_29.log
====================STDOUT ENTRIES==================
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-console-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-console-l1-2-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-datetime-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-debug-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-errorhandling-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-fibers-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-file-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-file-l1-2-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-file-l2-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-handle-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-heap-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-interlocked-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-libraryloader-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-localization-l1-2-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-memory-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-namedpipe-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-processenvironment-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-processthreads-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-processthreads-l1-1-1.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-profile-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-rtlsupport-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-string-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-synch-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-synch-l1-2-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-sysinfo-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-timezone-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-core-util-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-conio-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-convert-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-environment-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-filesystem-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-heap-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-locale-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-math-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-multibyte-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-private-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-process-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-runtime-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-stdio-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-string-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-time-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\api-ms-win-crt-utility-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\bin\attach.dll
d:\NXP\S32DS.3.6.0\jre\bin\awt.dll
d:\NXP\S32DS.3.6.0\jre\bin\dt_shmem.dll
d:\NXP\S32DS.3.6.0\jre\bin\dt_socket.dll
d:\NXP\S32DS.3.6.0\jre\bin\fontmanager.dll
d:\NXP\S32DS.3.6.0\jre\bin\freetype.dll
d:\NXP\S32DS.3.6.0\jre\bin\instrument.dll
d:\NXP\S32DS.3.6.0\jre\bin\j2gss.dll
d:\NXP\S32DS.3.6.0\jre\bin\j2pcsc.dll
d:\NXP\S32DS.3.6.0\jre\bin\j2pkcs11.dll
d:\NXP\S32DS.3.6.0\jre\bin\jaas.dll
d:\NXP\S32DS.3.6.0\jre\bin\jabswitch.exe
d:\NXP\S32DS.3.6.0\jre\bin\jaccessinspector.exe
d:\NXP\S32DS.3.6.0\jre\bin\jaccesswalker.exe
d:\NXP\S32DS.3.6.0\jre\bin\jar.exe
d:\NXP\S32DS.3.6.0\jre\bin\jarsigner.exe
d:\NXP\S32DS.3.6.0\jre\bin\java.dll
d:\NXP\S32DS.3.6.0\jre\bin\javaaccessbridge.dll
d:\NXP\S32DS.3.6.0\jre\bin\javac.exe
d:\NXP\S32DS.3.6.0\jre\bin\javadoc.exe
d:\NXP\S32DS.3.6.0\jre\bin\javajpeg.dll
d:\NXP\S32DS.3.6.0\jre\bin\javap.exe
d:\NXP\S32DS.3.6.0\jre\bin\javaw.exe
d:\NXP\S32DS.3.6.0\jre\bin\jawt.dll
d:\NXP\S32DS.3.6.0\jre\bin\jcmd.exe
d:\NXP\S32DS.3.6.0\jre\bin\jconsole.exe
d:\NXP\S32DS.3.6.0\jre\bin\jdb.exe
d:\NXP\S32DS.3.6.0\jre\bin\jdeprscan.exe
d:\NXP\S32DS.3.6.0\jre\bin\jdeps.exe
d:\NXP\S32DS.3.6.0\jre\bin\jdwp.dll
d:\NXP\S32DS.3.6.0\jre\bin\jfr.exe
d:\NXP\S32DS.3.6.0\jre\bin\jhsdb.exe
d:\NXP\S32DS.3.6.0\jre\bin\jimage.dll
d:\NXP\S32DS.3.6.0\jre\bin\jimage.exe
d:\NXP\S32DS.3.6.0\jre\bin\jinfo.exe
d:\NXP\S32DS.3.6.0\jre\bin\jli.dll
d:\NXP\S32DS.3.6.0\jre\bin\jlink.exe
d:\NXP\S32DS.3.6.0\jre\bin\jmap.exe
d:\NXP\S32DS.3.6.0\jre\bin\jmod.exe
d:\NXP\S32DS.3.6.0\jre\bin\jpackage.dll
d:\NXP\S32DS.3.6.0\jre\bin\jpackage.exe
d:\NXP\S32DS.3.6.0\jre\bin\jps.exe
d:\NXP\S32DS.3.6.0\jre\bin\jrunscript.exe
d:\NXP\S32DS.3.6.0\jre\bin\jshell.exe
d:\NXP\S32DS.3.6.0\jre\bin\jsound.dll
d:\NXP\S32DS.3.6.0\jre\bin\jstack.exe
d:\NXP\S32DS.3.6.0\jre\bin\jstat.exe
d:\NXP\S32DS.3.6.0\jre\bin\jstatd.exe
d:\NXP\S32DS.3.6.0\jre\bin\keytool.exe
d:\NXP\S32DS.3.6.0\jre\bin\kinit.exe
d:\NXP\S32DS.3.6.0\jre\bin\klist.exe
d:\NXP\S32DS.3.6.0\jre\bin\ktab.exe
d:\NXP\S32DS.3.6.0\jre\bin\lcms.dll
d:\NXP\S32DS.3.6.0\jre\bin\le.dll
d:\NXP\S32DS.3.6.0\jre\bin\management.dll
d:\NXP\S32DS.3.6.0\jre\bin\management_agent.dll
d:\NXP\S32DS.3.6.0\jre\bin\management_ext.dll
d:\NXP\S32DS.3.6.0\jre\bin\mlib_image.dll
d:\NXP\S32DS.3.6.0\jre\bin\msvcp140.dll
d:\NXP\S32DS.3.6.0\jre\bin\net.dll
d:\NXP\S32DS.3.6.0\jre\bin\nio.dll
d:\NXP\S32DS.3.6.0\jre\bin\prefs.dll
d:\NXP\S32DS.3.6.0\jre\bin\rmi.dll
d:\NXP\S32DS.3.6.0\jre\bin\rmiregistry.exe
d:\NXP\S32DS.3.6.0\jre\bin\saproc.dll
d:\NXP\S32DS.3.6.0\jre\bin\serialver.exe
d:\NXP\S32DS.3.6.0\jre\bin\server
d:\NXP\S32DS.3.6.0\jre\bin\server\jvm.dll
d:\NXP\S32DS.3.6.0\jre\bin\splashscreen.dll
d:\NXP\S32DS.3.6.0\jre\bin\sspi_bridge.dll
d:\NXP\S32DS.3.6.0\jre\bin\sunmscapi.dll
d:\NXP\S32DS.3.6.0\jre\bin\ucrtbase.dll
d:\NXP\S32DS.3.6.0\jre\bin\vcruntime140.dll
d:\NXP\S32DS.3.6.0\jre\bin\vcruntime140_1.dll
d:\NXP\S32DS.3.6.0\jre\bin\verify.dll
d:\NXP\S32DS.3.6.0\jre\bin\w2k_lsa_auth.dll
d:\NXP\S32DS.3.6.0\jre\bin\windowsaccessbridge-64.dll
d:\NXP\S32DS.3.6.0\jre\bin\zip.dll
d:\NXP\S32DS.3.6.0\jre\conf
d:\NXP\S32DS.3.6.0\jre\conf\logging.properties
d:\NXP\S32DS.3.6.0\jre\conf\management
d:\NXP\S32DS.3.6.0\jre\conf\management\jmxremote.access
d:\NXP\S32DS.3.6.0\jre\conf\management\jmxremote.password.template
d:\NXP\S32DS.3.6.0\jre\conf\management\management.properties
d:\NXP\S32DS.3.6.0\jre\conf\net.properties
d:\NXP\S32DS.3.6.0\jre\conf\security
d:\NXP\S32DS.3.6.0\jre\conf\security\java.policy
d:\NXP\S32DS.3.6.0\jre\conf\security\java.security
d:\NXP\S32DS.3.6.0\jre\conf\security\policy
d:\NXP\S32DS.3.6.0\jre\conf\security\policy\limited
d:\NXP\S32DS.3.6.0\jre\conf\security\policy\limited\default_local.policy
d:\NXP\S32DS.3.6.0\jre\conf\security\policy\limited\default_US_export.policy
d:\NXP\S32DS.3.6.0\jre\conf\security\policy\limited\exempt_local.policy
d:\NXP\S32DS.3.6.0\jre\conf\security\policy\README.txt
d:\NXP\S32DS.3.6.0\jre\conf\security\policy\unlimited
d:\NXP\S32DS.3.6.0\jre\conf\security\policy\unlimited\default_local.policy
d:\NXP\S32DS.3.6.0\jre\conf\security\policy\unlimited\default_US_export.policy
d:\NXP\S32DS.3.6.0\jre\conf\sound.properties
d:\NXP\S32DS.3.6.0\jre\include
d:\NXP\S32DS.3.6.0\jre\include\classfile_constants.h
d:\NXP\S32DS.3.6.0\jre\include\jawt.h
d:\NXP\S32DS.3.6.0\jre\include\jdwpTransport.h
d:\NXP\S32DS.3.6.0\jre\include\jni.h
d:\NXP\S32DS.3.6.0\jre\include\jvmti.h
d:\NXP\S32DS.3.6.0\jre\include\jvmticmlr.h
d:\NXP\S32DS.3.6.0\jre\include\win32
d:\NXP\S32DS.3.6.0\jre\include\win32\bridge
d:\NXP\S32DS.3.6.0\jre\include\win32\bridge\AccessBridgeCallbacks.h
d:\NXP\S32DS.3.6.0\jre\include\win32\bridge\AccessBridgeCalls.h
d:\NXP\S32DS.3.6.0\jre\include\win32\bridge\AccessBridgePackages.h
d:\NXP\S32DS.3.6.0\jre\include\win32\jawt_md.h
d:\NXP\S32DS.3.6.0\jre\include\win32\jni_md.h
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-console-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-console-l1-2-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-datetime-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-debug-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-errorhandling-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-file-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-file-l1-2-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-file-l2-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-handle-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-heap-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-interlocked-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-libraryloader-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-localization-l1-2-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-memory-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-namedpipe-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-processenvironment-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-processthreads-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-processthreads-l1-1-1.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-profile-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-rtlsupport-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-string-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-synch-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-synch-l1-2-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-sysinfo-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-timezone-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-core-util-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-conio-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-convert-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-environment-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-filesystem-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-heap-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-locale-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-math-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-multibyte-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-private-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-process-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-runtime-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-stdio-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-string-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-time-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\api-ms-win-crt-utility-l1-1-0.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\decora_sse.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\fxplugins.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\glass.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\glib-lite.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\gstreamer-lite.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\javafx_font.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\javafx_iio.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\jfxmedia.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\jfxwebkit.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\msvcp140.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\msvcp140_1.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\msvcp140_2.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\prism_common.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\prism_d3d.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\prism_sw.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\ucrtbase.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\vcruntime140.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\bin\vcruntime140_1.dll
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.base
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.base\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.base\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.base\LICENSE
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.controls
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.controls\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.controls\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.controls\LICENSE
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.fxml
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.fxml\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.fxml\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.fxml\LICENSE
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.graphics
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.graphics\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.graphics\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.graphics\jpeg_fx.md
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.graphics\LICENSE
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.graphics\mesa3d.md
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.media
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.media\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.media\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.media\directshow.md
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.media\glib.md
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.media\gstreamer.md
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.media\libffi.md
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.media\LICENSE
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.swing
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.swing\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.swing\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.swing\LICENSE
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.web
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.web\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.web\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.web\icu_web.md
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.web\libxml2.md
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.web\libxslt.md
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.web\LICENSE
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\legal\javafx.web\webkit.md
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\lib
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\lib\javafx-swt.jar
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\lib\javafx.base.jar
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\lib\javafx.controls.jar
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\lib\javafx.fxml.jar
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\lib\javafx.graphics.jar
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\lib\javafx.media.jar
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\lib\javafx.properties
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\lib\javafx.swing.jar
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\lib\javafx.web.jar
d:\NXP\S32DS.3.6.0\jre\javafx-sdk-17.0.12\src.zip
d:\NXP\S32DS.3.6.0\jre\legal
d:\NXP\S32DS.3.6.0\jre\legal\java.base
d:\NXP\S32DS.3.6.0\jre\legal\java.base\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.base\aes.md
d:\NXP\S32DS.3.6.0\jre\legal\java.base\asm.md
d:\NXP\S32DS.3.6.0\jre\legal\java.base\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.base\c-libutl.md
d:\NXP\S32DS.3.6.0\jre\legal\java.base\cldr.md
d:\NXP\S32DS.3.6.0\jre\legal\java.base\icu.md
d:\NXP\S32DS.3.6.0\jre\legal\java.base\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.base\public_suffix.md
d:\NXP\S32DS.3.6.0\jre\legal\java.base\unicode.md
d:\NXP\S32DS.3.6.0\jre\legal\java.base\wepoll.md
d:\NXP\S32DS.3.6.0\jre\legal\java.base\zlib.md
d:\NXP\S32DS.3.6.0\jre\legal\java.compiler
d:\NXP\S32DS.3.6.0\jre\legal\java.compiler\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.compiler\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.compiler\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.datatransfer
d:\NXP\S32DS.3.6.0\jre\legal\java.datatransfer\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.datatransfer\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.datatransfer\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\colorimaging.md
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\freetype.md
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\giflib.md
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\harfbuzz.md
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\jpeg.md
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\lcms.md
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\libpng.md
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.desktop\mesa3d.md
d:\NXP\S32DS.3.6.0\jre\legal\java.instrument
d:\NXP\S32DS.3.6.0\jre\legal\java.instrument\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.instrument\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.instrument\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.logging
d:\NXP\S32DS.3.6.0\jre\legal\java.logging\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.logging\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.logging\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.management
d:\NXP\S32DS.3.6.0\jre\legal\java.management\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.management\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.management\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.management.rmi
d:\NXP\S32DS.3.6.0\jre\legal\java.management.rmi\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.management.rmi\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.management.rmi\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.naming
d:\NXP\S32DS.3.6.0\jre\legal\java.naming\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.naming\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.naming\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.net.http
d:\NXP\S32DS.3.6.0\jre\legal\java.net.http\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.net.http\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.net.http\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.prefs
d:\NXP\S32DS.3.6.0\jre\legal\java.prefs\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.prefs\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.prefs\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.rmi
d:\NXP\S32DS.3.6.0\jre\legal\java.rmi\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.rmi\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.rmi\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.scripting
d:\NXP\S32DS.3.6.0\jre\legal\java.scripting\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.scripting\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.scripting\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.se
d:\NXP\S32DS.3.6.0\jre\legal\java.se\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.se\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.se\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.security.jgss
d:\NXP\S32DS.3.6.0\jre\legal\java.security.jgss\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.security.jgss\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.security.jgss\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.security.sasl
d:\NXP\S32DS.3.6.0\jre\legal\java.security.sasl\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.security.sasl\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.security.sasl\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.smartcardio
d:\NXP\S32DS.3.6.0\jre\legal\java.smartcardio\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.smartcardio\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.smartcardio\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.sql
d:\NXP\S32DS.3.6.0\jre\legal\java.sql\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.sql\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.sql\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.sql.rowset
d:\NXP\S32DS.3.6.0\jre\legal\java.sql.rowset\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.sql.rowset\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.sql.rowset\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.transaction.xa
d:\NXP\S32DS.3.6.0\jre\legal\java.transaction.xa\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.transaction.xa\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.transaction.xa\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.xml
d:\NXP\S32DS.3.6.0\jre\legal\java.xml\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.xml\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.xml\bcel.md
d:\NXP\S32DS.3.6.0\jre\legal\java.xml\dom.md
d:\NXP\S32DS.3.6.0\jre\legal\java.xml\jcup.md
d:\NXP\S32DS.3.6.0\jre\legal\java.xml\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.xml\xalan.md
d:\NXP\S32DS.3.6.0\jre\legal\java.xml\xerces.md
d:\NXP\S32DS.3.6.0\jre\legal\java.xml.crypto
d:\NXP\S32DS.3.6.0\jre\legal\java.xml.crypto\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\java.xml.crypto\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\java.xml.crypto\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\java.xml.crypto\santuario.md
d:\NXP\S32DS.3.6.0\jre\legal\jdk.accessibility
d:\NXP\S32DS.3.6.0\jre\legal\jdk.accessibility\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.accessibility\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.accessibility\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.attach
d:\NXP\S32DS.3.6.0\jre\legal\jdk.attach\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.attach\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.attach\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.charsets
d:\NXP\S32DS.3.6.0\jre\legal\jdk.charsets\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.charsets\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.charsets\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.compiler
d:\NXP\S32DS.3.6.0\jre\legal\jdk.compiler\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.compiler\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.compiler\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.cryptoki
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.cryptoki\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.cryptoki\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.cryptoki\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.cryptoki\pkcs11cryptotoken.md
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.cryptoki\pkcs11wrapper.md
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.ec
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.ec\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.ec\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.ec\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.mscapi
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.mscapi\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.mscapi\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.crypto.mscapi\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.dynalink
d:\NXP\S32DS.3.6.0\jre\legal\jdk.dynalink\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.dynalink\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.dynalink\dynalink.md
d:\NXP\S32DS.3.6.0\jre\legal\jdk.dynalink\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.editpad
d:\NXP\S32DS.3.6.0\jre\legal\jdk.editpad\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.editpad\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.editpad\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.hotspot.agent
d:\NXP\S32DS.3.6.0\jre\legal\jdk.hotspot.agent\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.hotspot.agent\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.hotspot.agent\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.httpserver
d:\NXP\S32DS.3.6.0\jre\legal\jdk.httpserver\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.httpserver\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.httpserver\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.ed
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.ed\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.ed\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.ed\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.jvmstat
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.jvmstat\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.jvmstat\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.jvmstat\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.le
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.le\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.le\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.le\jline.md
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.le\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.opt
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.opt\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.opt\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.opt\jopt-simple.md
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.opt\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.ci
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.ci\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.ci\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.ci\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.compiler
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.compiler\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.compiler\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.compiler\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.compiler.management
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.compiler.management\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.compiler.management\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.internal.vm.compiler.management\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jartool
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jartool\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jartool\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jartool\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.javadoc
d:\NXP\S32DS.3.6.0\jre\legal\jdk.javadoc\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.javadoc\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.javadoc\jquery.md
d:\NXP\S32DS.3.6.0\jre\legal\jdk.javadoc\jqueryUI.md
d:\NXP\S32DS.3.6.0\jre\legal\jdk.javadoc\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jcmd
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jcmd\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jcmd\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jcmd\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jconsole
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jconsole\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jconsole\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jconsole\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdeps
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdeps\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdeps\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdeps\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdi
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdi\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdi\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdi\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdwp.agent
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdwp.agent\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdwp.agent\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jdwp.agent\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jfr
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jfr\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jfr\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jfr\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jlink
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jlink\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jlink\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jlink\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jpackage
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jpackage\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jpackage\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jpackage\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jshell
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jshell\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jshell\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jshell\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jsobject
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jsobject\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jsobject\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jsobject\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jstatd
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jstatd\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jstatd\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.jstatd\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.localedata
d:\NXP\S32DS.3.6.0\jre\legal\jdk.localedata\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.localedata\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.localedata\cldr.md
d:\NXP\S32DS.3.6.0\jre\legal\jdk.localedata\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.localedata\thaidict.md
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management.agent
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management.agent\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management.agent\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management.agent\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management.jfr
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management.jfr\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management.jfr\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.management.jfr\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.naming.dns
d:\NXP\S32DS.3.6.0\jre\legal\jdk.naming.dns\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.naming.dns\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.naming.dns\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.naming.rmi
d:\NXP\S32DS.3.6.0\jre\legal\jdk.naming.rmi\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.naming.rmi\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.naming.rmi\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.net
d:\NXP\S32DS.3.6.0\jre\legal\jdk.net\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.net\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.net\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.nio.mapmode
d:\NXP\S32DS.3.6.0\jre\legal\jdk.nio.mapmode\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.nio.mapmode\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.nio.mapmode\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.random
d:\NXP\S32DS.3.6.0\jre\legal\jdk.random\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.random\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.random\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.sctp
d:\NXP\S32DS.3.6.0\jre\legal\jdk.sctp\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.sctp\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.sctp\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.security.auth
d:\NXP\S32DS.3.6.0\jre\legal\jdk.security.auth\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.security.auth\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.security.auth\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.security.jgss
d:\NXP\S32DS.3.6.0\jre\legal\jdk.security.jgss\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.security.jgss\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.security.jgss\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.unsupported
d:\NXP\S32DS.3.6.0\jre\legal\jdk.unsupported\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.unsupported\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.unsupported\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.unsupported.desktop
d:\NXP\S32DS.3.6.0\jre\legal\jdk.unsupported.desktop\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.unsupported.desktop\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.unsupported.desktop\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.xml.dom
d:\NXP\S32DS.3.6.0\jre\legal\jdk.xml.dom\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.xml.dom\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.xml.dom\LICENSE
d:\NXP\S32DS.3.6.0\jre\legal\jdk.zipfs
d:\NXP\S32DS.3.6.0\jre\legal\jdk.zipfs\ADDITIONAL_LICENSE_INFO
d:\NXP\S32DS.3.6.0\jre\legal\jdk.zipfs\ASSEMBLY_EXCEPTION
d:\NXP\S32DS.3.6.0\jre\legal\jdk.zipfs\LICENSE
d:\NXP\S32DS.3.6.0\jre\lib
d:\NXP\S32DS.3.6.0\jre\lib\classlist
d:\NXP\S32DS.3.6.0\jre\lib\ct.sym
d:\NXP\S32DS.3.6.0\jre\lib\fontconfig.bfc
d:\NXP\S32DS.3.6.0\jre\lib\fontconfig.properties.src
d:\NXP\S32DS.3.6.0\jre\lib\jawt.lib
d:\NXP\S32DS.3.6.0\jre\lib\jfr
d:\NXP\S32DS.3.6.0\jre\lib\jfr\default.jfc
d:\NXP\S32DS.3.6.0\jre\lib\jfr\profile.jfc
d:\NXP\S32DS.3.6.0\jre\lib\jrt-fs.jar
d:\NXP\S32DS.3.6.0\jre\lib\jvm.cfg
d:\NXP\S32DS.3.6.0\jre\lib\jvm.lib
d:\NXP\S32DS.3.6.0\jre\lib\modules
d:\NXP\S32DS.3.6.0\jre\lib\psfont.properties.ja
d:\NXP\S32DS.3.6.0\jre\lib\psfontj2d.properties
d:\NXP\S32DS.3.6.0\jre\lib\security
d:\NXP\S32DS.3.6.0\jre\lib\security\blocked.certs
d:\NXP\S32DS.3.6.0\jre\lib\security\cacerts
d:\NXP\S32DS.3.6.0\jre\lib\security\default.policy
d:\NXP\S32DS.3.6.0\jre\lib\security\public_suffix_list.dat
d:\NXP\S32DS.3.6.0\jre\lib\src.zip
d:\NXP\S32DS.3.6.0\jre\lib\tzdb.dat
d:\NXP\S32DS.3.6.0\jre\lib\tzmappings
d:\NXP\S32DS.3.6.0\jre\org.eclipse.justj.properties
d:\NXP\S32DS.3.6.0\jre\release
d:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\.com.zerog.registry.xml
d:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\InstallScript.iap_xml
d:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\uninstaller.jar
(X) storing replay variable manager
3,076 次查看
jiri_kral
are you starting S32DS installer with admin rights? Can you please share install log? With default install path is the log file located in c:\NXP\S32DS.3.6.0\_S32 Design Studio for S32 Platform 3.6.0_installation\Logs\
