View Code does not work for FreeRTOS functions
freddy_ben-zeev
When attempting to view the code of a FreeRTOS function (by double-clicking on it in the "components" window, or right-click and select "View Code") I get the error "Code for method has not been generated yet". The FreeRTOS component was added to the project (it shows in the components window under "OSs") and the Processot Expert generator was run. If I do a global search the functions I tried to see are inside the project under SDK/rtos/FreeRTOS_S32K/sources. Seems like a bug...
