Using Bluetooth in S32K144 Board
1,714 次查看
MarooNarae
Hi, All.
I want to activate Bluetooth function(with HC-06) on S32K144 board.
I recently started using this board, so can anyone tell me how to use bluetooth in this board briefly....?
I really wanted to make it, so please help...
Thanks.
标记 (2)
1 回复
1,704 次查看
jiri_kral
I'm not sure where is the problem - just hook up the HC-06 to the board. You need to connect power and Uart TX/RX. There is nothing special about it.
You can find EVB pinout in getting started guide: https://www.nxp.com/document/guide/get-started-with-the-s32k144evb:NGS-S32K144EVB
You can modify an existing HC-06 driver for Arduino or write your own one.
