Unable to resolve Semantic errors in S32 design studio
1,582 次查看
Anilpatil_SasvaAuto
Hello Team,
I am trying to compile the NFC reader library project. After a successful build, I did not encounter any compilation errors or warnings; however, I found two semantic errors in the Problems window.
These errors appear even after I have provided the path to include in the IDE settings. Please note that these errors will not be displayed in the Problems window unless you open the "phbalReg_S32kSpi.c" file from the DAL folder.
Please refer to the attached files for your reference
I would appreciate any solutions to resolve the symbols or errors. Thank you!
1,315 次查看
jiri_kral
I'm not able reproduce the issue. Can you please share the screenshot with the errors and ideally with error details if there are some?
6 回复数
847 次查看
Anilpatil_SasvaAuto
Issue resolved from my side
1,567 次查看
jiri_kral
what's your S32DS version and target MCU?
1,544 次查看
Anilpatil_SasvaAuto
S32DS version: 3.4
Target MCU:S32K144EVB
1,529 次查看
jiri_kral
And which particular version of NFC Reader library are you using?
1,497 次查看
Anilpatil_SasvaAuto
NFC reader library version number: aNfcRdLib_SDK_Evaluation_v2.28
1,316 次查看
jiri_kral
