Some questions about compiling with S32 Design Studio for ARM Version 2.2
803件の閲覧回数
yangkunlin
I encountered the following issues during the development of the S32K144
Listen to the suggestions of colleagues to open the optimization level, but still compile Failed
679件の閲覧回数
stanish
According to you screenshot the linker detects overlap between .backup and .code sections.
I'd recommend you to check generated .map file to confirm the overlap and adjust linker command file (.ld) section .backup or .code to avoid overlap between these two.
Hope it helps
Stan
