SDKv1.9.0 for S32K
SDKv1.9.0 for S32K
1,948 次查看
yoelvyao
HI
I installed the sdk v1.9.0 in the S32DS 2018.R1 for arm, but when I created a new project , I could only see the sdk v0.8.6. What should I do?
标记 (3)
1,770 次查看
mikedoidge
Hello Yoelv Yao,
The S32K14x SDK 1.9.0 only supports GCC 6.3. So you will need to select 'ARM Bare-Metal 32-bit Target Binary Toolchain' in the ToolChain Selections menu of the New Project Wizard. I have updated the announcement to reflect this detail. https://community.nxp.com/docs/DOC-340654
Mike
1,770 次查看
mikedoidge
Thank you for reporting this. It has been shared with the development team and they are investigating. I will provide update when there is a workaround or updated release of Update 4.
Mike
