S32ds_2018R1安装后又安装UP9,结果还是报错
1900156628
SOS,项目开发,急急急,求助,不知道怎么解决。
jiri_kral
can you please share more details? What is SDK version? Processor expert code can be generated successfully? Can you share output from build console?
Jiri
1900156628
Dear Mr.Jiri,
Hello!  My name is Guo Xinyu. I'm from Shanghai.I am a MCU Engineer about automotive electronics
It's a great honor to hear from you. SDK version is S32DS_ARM_v2018.R1_UP9  or  S32DS_ARM_v2018.R1_UP11.The main problem I'm currently facing is using s32ds_ 2018r1 cannot generate.O file. I have tried for several days, but I can't. please help me. Thank you very much.Can you leave your contact information?
Yours sincerely,
Guoxinyu
jiri_kral
you can try delete content of Generated Code and content of Debug folder (in my case it is Debug_FLASH).
Then generate again processor expert code and start build:
BR,
Jiri
