S32V234 M4 example
S32V234 M4 example
1,179件の閲覧回数
SagiSalomon
I am able to build for M4 target with freeRTOS using an example provided by the development kit.
I wish to burn/copy the elf to the board itself and see it runs.
What is the procedure in order to do so? I didnt find any way to use the elf file for the M4.
I am able to connect to the board using serial and ssh (linux core) and boot sequence from A53 (default configuration).
No debugging tool.
0 返答(返信)
