S32K312 auto compilation
Nancy_LAN
the customer: GOSUNCN
the platform: S32K312
hi support:
    How to use commands to achieve automated compilation based on S32DS3.5.13?
stanish
I'd suggest you see the HOWTO document that describes how to control S32DS project from command  line.
it's available in S32 Design Studio: (c:\NXP\S32DS.3.6.3\S32DS\help\resources\howto\HOWTO_S32_Design_Studio_Command_Line_Interface.pdf)
I've attached to the post for your convenince.
Hope it helps.
Stan
stanish
Hope it helps.
Stan
%3CLINGO-SUB%20id%3D%22lingo-sub-2160498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K312%20auto%20compilation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2160498%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ethe%20customer%3A%20GOSUNCN%3C%2FP%3E%3CP%3Ethe%20platform%3A%20S32K312%3C%2FP%3E%3CP%3Ehi%20support%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%26nbsp%3BHow%20to%20use%20commands%20to%20achieve%20automated%20compilation%20based%20on%20S32DS3.5.13%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2160859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K312%20auto%20compilation%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2160859%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%0A%3CP%3EI'd%20suggest%20you%20see%20the%26nbsp%3BHOWTO%20document%20that%20describes%20how%20to%20control%20S32DS%20project%20from%20command%26nbsp%3B%20line.%3C%2FP%3E%0A%3CP%3Eit's%20available%20in%20S32%20Design%20Studio%3A%20(c%3A%5CNXP%5CS32DS.3.6.3%5CS32DS%5Chelp%5Cresources%5Chowto%5CHOWTO_S32_Design_Studio_Command_Line_Interface.pdf)%3C%2FP%3E%0A%3CP%3EI've%20attached%20to%20the%20post%20for%20your%20convenince.%3C%2FP%3E%0A%3CP%3EHope%20it%20helps.%3C%2FP%3E%0A%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E
