S32K148 Design Studio - EmbSys Registers not showing
3,730 次查看
jakub_mielczare
I have a fresh installation of S32 Design Studio for S32K148 (2019 R1).
When I run debug session the EmbSys Registers view is empty (see attached screenshot). The target is paused. Also the Memory View shows "????" in peripheral registers.
Can you help?
Jakub
标记 (3)
3,648 次查看
Robin_Shen
Hi Jakub,
Are you able to configure the EmbSys Registers and then select the chip for it?
Here is the version of my EmbSysRegView.
For the Memory View, would you please observe other address that available? 0x40050018 is Reserved for S32K148.
Robin
3,649 次查看
Robin_Shen
Hi Jakub,
Robin
3,648 次查看
jakub_mielczare
Hi Robin,
Selecting proper device in EmbSys Registers settings solved the issue.
Thank you,
Jakub
