S32K146 Single Step not stepping correctly
2,094件の閲覧回数
albie5
Can anybody advise as to why Single Step functions step-into and step-over both perform the same step-into function. Am I missing some setting somewhere?
タグ(3)
3 返答(返信)
1,990件の閲覧回数
albie5
We're using our own project and its optimized code, is that the problem?
1,990件の閲覧回数
jiri_kral
yes, in some cases it may be an issue. For debugging purposes is better solution use non-optimized code.
Jiri
1,990件の閲覧回数
jiri_kral
can you provide more details like screenshots? Are you using some example or your own project? Did you enabled optimizations?
Jiri
