S32K146 P&E debugger support in the S32DS for ARM 2018.R1
已解决
跳至解决方案
6,452 次查看
james-lee
Hello team,
I've installed the S32DS for ARM 2018.R1 and all updates by 'Help-Install New Software' menu. When I created the flash_partitioning_s32k146 project from Example and tried to configure the P&E debugger settings, I could not find the S32K146 and it just showed the S32K144 only in the S32K1 family.
Please look at the attached and give me an advice about how to resolve this.
James
标签 (1)
1 解答
6,442 次查看
jiri_kral
Hi James,
I can reproduce your issue, it looks that PE Micro plugin contains some bug. Please uninstall PE Micro plugins:
And install older PE Micro plugin version - v4.7.8:
BR,
Jiri
在原帖中查看解决方案
3 回复数
6,448 次查看
james-lee
Please find one strange message attached.
The GNU ARM PEMicro Interface Debugging Support v3.5.6 is shown in the update list, but after trying to install it, it is ignored because a newer version is already installed. In the device lists, I can see the S32K2TV and S32K3 devices but the S32K144 only is available in the S32K1 family.
James
6,443 次查看
jiri_kral
Hi James,
BR,
Jiri
6,432 次查看
james-lee
Hi Jiri,
Thank you for your answer and I can use the P&E debugger.
I need to remove two files
  - GNU ARM PEMicro Interface Debugging Support v4.8.5
  - PEMicro ARM Device Expension Plugin v4.8.5 (you mentioned)
James
