S32K144 How to make CAN network by CRC module?
4,095 次查看
tkdwofl
hi!!!
i used s32k144 Design studio.
Is the CAN communication applied using the CRC module?
If it is incorrect. How to make CAN network by CRC?
Thank you for providing the example code.
标记 (4)
5 回复数
3,890 次查看
jiri_kral
the FlexCAN module counts CRC by itself. FlexCAN is fully supporting ISO 11898-1 standard.
Jiri
3,890 次查看
tkdwofl
Can I check the code of the FlexCAN module itself to calculate the CRC? (For example, a Header file, a predefined CRC value.)
3,890 次查看
jiri_kral
the CRC is done by hardware itself. You can check the  CANx->CRCR (chapter 53.4.2.14 in Reference Manual) register or capture CRC on oscilloscope.
Jiri
3,890 次查看
tkdwofl
OK i see.
but i want to make a fault on CRC with CAN.
How to make a fault CRC within CAN?
Please help me with my question.
Thanks..
3,890 次查看
jiri_kral
I'm afraid that the only possibility how to inject CAN CRC error is modify physical layer - for example very short line drop affecting couple bits in payload.
Jiri
