S32K144_CRC-16-IBM
S32K144_CRC-16-IBM
2,421 次查看
kwakd_y
I would like to modify the CRC example code provided by the S32 DS.
Example code is "CCITT 16 bits standard" but I have to use  "CRC-16-IBM"
Which part should I modify?
Can you provide a fix code?
The example code is "crc_checksum_s32k144" in the S32 design studio.
- .CRC-16-CCITT (x16 + x12 + x5 + 1)
- .CRC-16-IBM (x16 + x15 + x2 + 1)
 In example code
 /*!< CRC Polynomial, MSBit first.<br/>
 *   Example polynomial: 0x1021U = 1_0000_0010_0001 = x^12+x^5+1 */
标签 (2)
标记 (3)
2,105 次查看
jiri_kral
you can modify processor expert CRC module (double click to crc1:crc in components)  to met your needs:
Jiri
