S32K cmake math.h
S32K cmake math.h
2,830件の閲覧回数
Ralphty
Dears:
When I am compiling an S32K project using cmake, when I add the sin() function in the math. h library, an undefined reference to 'sin' appears during the linking process. What is the reason for this.
Ralphty_0-1699429748835.pngRalphty_0-1699429748835.pngRalphty_1-1699429768375.pngRalphty_1-1699429768375.png
Thanks!!!
タグ(1)
3 返答(返信)
2,808件の閲覧回数
davidtosenovjan
2,793件の閲覧回数
Ralphty
Dear:
Thank you very much for your reply. I did not use the IDE for project construction, but instead used cmake as the construction method. I also added - lc - lm - lgcc in the link options, but still reported the above issue.
2,534件の閲覧回数
drfrefw123
Dear:
I have the same problem. Have you solved it?
