S32K Debug Stuck at 99%
3,712 次查看
bjrajendra
Senior Contributor I
Hello all,
Currently, I'm using the S32K146 device ith S32DS IDE,
I tried to program & debug the software but it got stuck at 99%. Failed to program the software.
Unfortunately, it didn’t download and got stuck at 99% even after a long time.
Kindly suggest if I missed something
Raju
标记 (1)
2,809 次查看
juan_see
Hi all,
The plugin you are using it is a bit outdated. PEmicro's latest official plugin is 5.3.6.202210191804. To update the plugin, please follow the steps outlined in the following blogpost:
https://www.pemicro.com/blog/index.cfm?post_id=124
You do not need to install the "PEmicro ARM Device Expansion Plugin"
3,397 次查看
HyperFrank
I have the exact same problem right now. Did you find a solution?
I tried uninstalling and reinstalling S32DS, but no success
