S32Ds for ARM, No Java virtual machine could be found from your PATH
2,842件の閲覧回数
dixonsco
I'm trying to install S32DS on ubuntu 22.04 aarch64 and I have openjdk 11.0.22 installed but when I try to run the installer I get:
./S32DS_ARM_Linux_v2.2.bin
Preparing to install
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
environment variable. You must install a VM prior to
running this program.
What am I missing here?
2,826件の閲覧回数
jiri_kral
S32DS for Arm v2.2 requires Java v1.8. Please make sure that you met all Linux requirements from installation guide.
