S32DS3.6 CMD compile
SimonC
I want to use the command line on this Windows system to compile MCU software after EB MCAL configuration.
The current situation is: I can already compile the project using DS3.6, but I cannot find documentation or examples on how to compile using the command line.
I hope to get some help.
Tags (2)
Julián_AragónM
Hi @SimonC,
You can refer to other community posts for some guidance: How to use build projects in command line for S32K144 - NXP Community.
However, S32DS has some help contents for command line execution:
Julián
