S32DS for Arm "Failed to create the Java Virtual Machine"
1,571 次查看
rmaier
Initially, I had some issues with S32DS regarding the PE Micro drivers. I could no longer debug after updating the drivers in the IDE. So, I went ahead and reinstalled S32DS for Arm v2.2.
Now, I get "Failed to create the Java Virtual Machine" when I run the application. Any tips on how to correct this?
Thanks!
1,540 次查看
rmaier
I fixed it by uninstalling and manually deleting any vestiges on the machine and doing a clean reinstall.
Robert
1,545 次查看
jiri_kral
can you please share screenshot with the error message?
