[S32DS] eclipse - java.io.FileNotFoundException !?
225件の閲覧回数
CY9
I have no folder named `git` under C:\
My `git-for-windows.ico` file is under  D:\msys64\mingw64\share\git\git-for-windows.ico
Everytime I compiled something, it pop up.
It's annoying.
org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTException: i/o error (java.io.FileNotFoundException: C:\Git\mingw64\share\git\git-for-windows.ico (系統找不到指定的路徑。))
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4742)
at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:64)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java:361)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributionRecord.updateVisibility(ContributionRecord.java:113)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:191)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:202)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.showMenu(MenuManagerShowProcessor.java:256)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.menuAboutToHide(MenuManagerShowProcessor.java:114)
at org.eclipse.jface.internal.MenuManagerEventHelper.showEventPostHelper(MenuManagerEventHelper.java:95)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:469)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:463)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:495)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:259)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4209)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1043)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1067)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1048)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:5157)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4789)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1480)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2263)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4930)
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:237)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:4067)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3620)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1157)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:654)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1462)
Caused by: org.eclipse.swt.SWTException: i/o error (java.io.FileNotFoundException: C:\Git\mingw64\share\git\git-for-windows.ico (系統找不到指定的路徑。))
at org.eclipse.swt.SWT.error(SWT.java:4893)
at org.eclipse.swt.SWT.error(SWT.java:4808)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:184)
at org.eclipse.tm.terminal.view.ui.local.showin.ExternalExecutablesUtils.loadImage(ExternalExecutablesUtils.java:38)
at org.eclipse.tm.terminal.view.ui.local.showin.DynamicContributionItems.getContributionItems(DynamicContributionItems.java:74)
at org.eclipse.ui.actions.CompoundContributionItem.getContributionItemsToFill(CompoundContributionItem.java:83)
at org.eclipse.ui.actions.CompoundContributionItem.fill(CompoundContributionItem.java:57)
at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java:146)
at org.eclipse.jface.action.MenuManager.doItemFill(MenuManager.java:729)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:806)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:673)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.scheduleManagerUpdate(MenuManagerRenderer.java:1227)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.subscribeUIElementTopicVisible(MenuManagerRenderer.java:213)
at jdk.internal.reflect.GeneratedMethodAccessor35.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
... 63 more
Caused by: java.io.FileNotFoundException: C:\Git\mingw64\share\git\git-for-windows.ico (系統找不到指定的路徑。)
at java.base/java.io.FileInputStream.open0(Native Method)
at java.base/java.io.FileInputStream.open(Unknown Source)
at java.base/java.io.FileInputStream.<init>(Unknown Source)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:181)
... 77 more
162件の閲覧回数
VaneB
Hi @CY9
Sorry about that, I shared the wrong location. The settings I mentioned previously cannot be edited. Instead, please go to:
Window → Preferences → Terminal → Local Terminal and check the "Show In..." Custom Entries section.
This is where you can look for Git paths.
4 返答(返信)
186件の閲覧回数
VaneB
Hi @CY9
As shown in the error message, S32DS is unable to find the git-for-windows.ico in the configured locations. Try pointing to the correct path on your system. To do this, navigate to:
Window → Preferences → Team → Git → Configuration → System Settings
Then update the location so that it matches the actual installation path on your machine.
BR, VaneB
174件の閲覧回数
CY9
I can *NOT* find any `C:\Git\...` exist. !?
163件の閲覧回数
VaneB
Hi @CY9
155件の閲覧回数
CY9
Correct !
It's empty path here :
[Edit]
~case closed~
%3CLINGO-SUB%20id%3D%22lingo-sub-2406448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BS32DS%5D%20eclipse%20-%20java.io.FileNotFoundException%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EC%3A%5C%20%E3%81%AE%E4%B8%8B%E3%81%AB%20%60git%60%20%E3%81%A8%E3%81%84%E3%81%86%E5%90%8D%E5%89%8D%E3%81%AE%E3%83%95%E3%82%A9%E3%83%AB%E3%83%80%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%60git-for-windows.ico%60%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%20D%3A%5Cmsys64%5Cmingw64%5Cshare%5Cgit%5Cgit-for-windows.ico%20%E3%81%AB%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%95%E3%81%8B%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%81%B3%E3%81%AB%E3%80%81%E3%81%9D%E3%82%8C%E3%81%8C%E3%83%9D%E3%83%83%E3%83%97%E3%82%A2%E3%83%83%E3%83%97%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%A4%E3%83%A9%E3%82%A4%E3%83%A9%E3%81%99%E3%82%8B%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787121511238.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787121511238.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787121511238.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787121511238.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394919iFCE07D0F8332EC2F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787121511238.png%22%20alt%3D%22CY9_0-1787121511238.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787121511238.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787121511238.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787121511238.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787121511238.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E--%3C%2FP%3E%3CDIV%3Eorg.eclipse.e4.core.di.InjectionException%3A%20org.eclipse.swt.SWTException%3A%20i%2Fo%20%E3%82%A8%E3%83%A9%E3%83%BC%20(java.io.FileNotFoundException%3A%20%3CU%3E%3CSTRONG%3EC%3A%5CGit%5Cmingw64%5Cshare%5Cgit%5Cgit-for-windows.ico%3C%2FSTRONG%3E%3C%2FU%3E%20(%E7%B3%BB%E7%B5%B1%E6%89%BE%E4%B8%8D%E5%88%B0%E6%8C%87%E5%AE%9A%E7%9A%84%E8%B7%AF%E5%BE%91%E3%80%82))%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java%3A68)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java%3A236)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java%3A133)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Display.syncExec(Display.java%3A4742)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java%3A34)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.internal.di.UIEventObjectSupplier%24UIEventHandler.handleEvent(UIEventObjectSupplier.java%3A64)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java%3A205)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java%3A203)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java%3A1)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java%3A234)%20%E3%81%A7%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java%3A151)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java%3A133)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java%3A75)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java%3A44)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java%3A55)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java%3A63)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java%3A424)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java%3A361)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.workbench.renderers.swt.ContributionRecord.updateVisibility(ContributionRecord.java%3A113)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java%3A191)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java%3A202)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.showMenu(MenuManagerShowProcessor.java%3A256)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.menuAboutToHide(MenuManagerShowProcessor.java%3A114)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.jface.internal.MenuManagerEventHelper.showEventPostHelper(MenuManagerEventHelper.java%3A95)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java%3A469)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.jface.action.MenuManager.access%241(MenuManager.java%3A463)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.jface.action.MenuManager%242.menuShown(MenuManager.java%3A495)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java%3A259)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java%3A89)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Display.sendEvent(Display.java%3A4209)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Widget.sendEvent(Widget.java%3A1043)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Widget.sendEvent(Widget.java%3A1067)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Widget.sendEvent(Widget.java%3A1048)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java%3A5157)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Control.windowProc(Control.java%3A4789)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Canvas.windowProc(Canvas.java%3A340)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Decorations.windowProc(Decorations.java%3A1480)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Shell.windowProc(Shell.java%3A2263)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Display.windowProc(Display.java%3A4930)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native%20%E6%96%B9%E6%B3%95)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Menu._setVisible(Menu.java%3A237)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Display.runPopups(Display.java%3A4067)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.widgets.Display.readAndDispatch(Display.java%3A3620)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine%245.run(PartRenderingEngine.java%3A1157)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java%3A338)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java%3A1046)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java%3A155)%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.ui.internal.Workbench.lambda%243(Workbench.java%3A644)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java%3A338)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java%3A551)%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java%3A156)%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java%3A152)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java%3A203)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java%3A134)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java%3A104)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java%3A401)%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java%3A255)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20java.base%2Fjdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native%20Method)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20java.base%2Fjdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown%20Source)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ejava.base%2Fjdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown)%20%E3%81%A7%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ejava.base%2Fjava.lang.reflect.Method.invoke(Unknown)%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.equinox.launcher.Main.invokeFramework(Main.java%3A654)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.equinox.launcher.Main.basicRun(Main.java%3A591)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.equinox.launcher.Main.run(Main.java%3A1462)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E5%8E%9F%E5%9B%A0%3A%20org.eclipse.swt.SWTException%3A%20i%2Fo%20%E3%82%A8%E3%83%A9%E3%83%BC%20(java.io.FileNotFoundException%3A%20C%3A%5CGit%5Cmingw64%5Cshare%5Cgit%5Cgit-for-windows.ico%20(%E7%B3%BB%E7%B5%B1%E6%89%BE%E4%B8%8D%E5%88%B0%E6%8C%87%E5%AE%9A%E7%9A%84%E8%B7%AF%E5%BE%91%E3%80%82))%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.SWT.error(SWT.java%3A4893)%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.SWT.error(SWT.java%3A4808)%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java%3A184)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.tm.terminal.view.ui.local.showin.ExternalExecutablesUtils.loadImage(ExternalExecutablesUtils.java%3A38)%20%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.tm.terminal.view.ui.local.showin.DynamicContributionItems.getContributionItems(DynamicContributionItems.java%3A74)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.ui.actions.CompoundContributionItem.getContributionItemsToFill(CompoundContributionItem.java%3A83)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.ui.actions.CompoundContributionItem.fill(CompoundContributionItem.java%3A57)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java%3A146)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.jface.action.MenuManager.doItemFill(MenuManager.java%3A729)%20%E3%81%A7%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.jface.action.MenuManager.update(MenuManager.java%3A806)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.jface.action.MenuManager.update(MenuManager.java%3A673)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.scheduleManagerUpdate(MenuManagerRenderer.java%3A1227)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.subscribeUIElementTopicVisible(MenuManagerRenderer.java%3A213)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ejdk.internal.reflect.GeneratedMethodAccessor35.invoke(Unknown)%20%E3%81%A7%E5%AE%9F%E8%A1%8C%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ejava.base%2Fjdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown)%20%E3%81%A7%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ejava.base%2Fjava.lang.reflect.Method.invoke(Unknown)%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java%3A58)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E...%E3%81%95%E3%82%89%E3%81%AB63%E4%BB%B6%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E5%8E%9F%E5%9B%A0%3A%20java.io.FileNotFoundException%3A%20C%3A%5CGit%5Cmingw64%5Cshare%5Cgit%5Cgit-for-windows.ico%20(%E7%B3%BB%E7%B5%B1%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E8%B7%AF%E5%BE%91%E3%80%82)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20java.base%2Fjava.io.FileInputStream.open0(Native%E6%96%B9%E6%B3%95)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20java.base%2Fjava.io.FileInputStream.open(Unknown%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20java.base%2Fjava.io.FileInputStream.%3CINIT%3E(Unknown%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%89%3C%2FINIT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eat%20java.base%2Fjava.io.FileInputStream.%3CINIT%3E(Unknown%E3%82%BD%E3%83%BC%E3%82%B9%EF%BC%89%3C%2FINIT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eorg.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java%3A181)%20%E3%81%A7%E7%99%BA%E7%94%9F%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E...%E3%81%95%E3%82%89%E3%81%AB77%E4%BB%B6%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32DS%5D%20eclipse%20-%20java.io.FileNotFoundException%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%80%8CC%3A%5CGit%5C...%E3%80%8D%E3%81%A8%E3%81%84%E3%81%86%E8%A8%80%E8%91%89%E3%81%AF*%E5%85%A8%E3%81%8F*%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82!%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787192155321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787192155321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787192155321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787192155321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394979iA8FA475870D2252F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787192155321.png%22%20alt%3D%22CY9_0-1787192155321.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787192155321.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787192155321.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787192155321.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787192155321.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32DS%5D%20eclipse%20-%20java.io.FileNotFoundException%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225755%22%20target%3D%22_blank%22%3E%40CY9%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AB%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%80%81S32DS%20%E3%81%AF%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E6%89%80%E3%81%AB%20git-for-windows.ico%20%E3%82%92%E8%A6%8B%E3%81%A4%E3%81%91%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E4%B8%8A%E3%81%AE%E6%AD%A3%E3%81%97%E3%81%84%E3%83%91%E3%82%B9%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%93%E3%82%8C%E3%82%92%E8%A1%8C%E3%81%86%E3%81%AB%E3%81%AF%E3%80%81%E6%AC%A1%E3%81%AE%E5%A0%B4%E6%89%80%E3%81%AB%E7%A7%BB%E5%8B%95%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%E2%86%92%20%E7%92%B0%E5%A2%83%E8%A8%AD%E5%AE%9A%20%E2%86%92%20%E3%83%81%E3%83%BC%E3%83%A0%20%E2%86%92%20Git%20%E2%86%92%20%E6%A7%8B%E6%88%90%20%E2%86%92%20%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0%E8%A8%AD%E5%AE%9A%3C%2FP%3E%0A%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E7%B5%8C%E8%B7%AF%E3%81%A8%E4%B8%80%E8%87%B4%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%A0%B4%E6%89%80%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%E3%80%81VaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2407085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32DS%5D%20eclipse%20-%20java.io.FileNotFoundException%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225755%22%20target%3D%22_blank%22%3E%40CY9%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E7%94%B3%E3%81%97%E8%A8%B3%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%9F%E5%A0%B4%E6%89%80%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%97%E3%81%BE%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E5%85%88%E3%81%BB%E3%81%A9%E8%BF%B0%E3%81%B9%E3%81%9F%E8%A8%AD%E5%AE%9A%E3%81%AF%E7%B7%A8%E9%9B%86%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E4%BB%A3%E3%82%8F%E3%82%8A%E3%81%AB%E3%80%81%E3%81%93%E3%81%A1%E3%82%89%E3%81%B8%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%A6%E3%82%A3%E3%83%B3%E3%83%89%E3%82%A6%20%E2%86%92%20%E7%92%B0%E5%A2%83%E8%A8%AD%E5%AE%9A%20%E2%86%92%20%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%20%E2%86%92%20%E3%83%AD%E3%83%BC%E3%82%AB%E3%83%AB%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E3%80%8C%E8%A1%A8%E7%A4%BA%E5%A0%B4%E6%89%80%E3%80%8D%E3%81%AE%E3%80%8C%E3%82%AB%E3%82%B9%E3%82%BF%E3%83%A0%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%80%8D%E3%82%BB%E3%82%AF%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%AB%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E5%85%A5%E3%82%8C%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%E3%81%93%E3%81%93%E3%81%A7Git%E3%83%91%E3%82%B9%E3%82%92%E6%8E%A2%E3%81%99%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2407140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32DS%5D%20eclipse%20-%20java.io.FileNotFoundException%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%AD%A3%E3%81%97%E3%81%84%20%EF%BC%81%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%93%E3%81%93%E3%81%AF%E7%A9%BA%E3%81%AE%E9%81%93%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787269588821.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787269588821.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395061i13B1CDE74ECB9FF8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787269588821.png%22%20alt%3D%22CY9_0-1787269588821.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787269588821.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787269588821.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%5B%E7%B7%A8%E9%9B%86%5D%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_1-1787269614644.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_1-1787269614644.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395062i9CFEEC3F0A41F54D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_1-1787269614644.png%22%20alt%3D%22CY9_1-1787269614644.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_1-1787269614644.png%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_1-1787269614644.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E~%E4%BA%8B%E4%BB%B6%E3%81%AF%E8%A7%A3%E6%B1%BA~%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
