[S32DS] eclipse - java.io.FileNotFoundException !?
567 次查看
CY9
I have no folder named `git` under C:\
My `git-for-windows.ico` file is under  D:\msys64\mingw64\share\git\git-for-windows.ico
Everytime I compiled something, it pop up.
It's annoying.
org.eclipse.e4.core.di.InjectionException: org.eclipse.swt.SWTException: i/o error (java.io.FileNotFoundException: C:\Git\mingw64\share\git\git-for-windows.ico (系統找不到指定的路徑。))
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4742)
at org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java:34)
at org.eclipse.e4.ui.internal.di.UIEventObjectSupplier$UIEventHandler.handleEvent(UIEventObjectSupplier.java:64)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:133)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java:361)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributionRecord.updateVisibility(ContributionRecord.java:113)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:191)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:202)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.showMenu(MenuManagerShowProcessor.java:256)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.menuAboutToHide(MenuManagerShowProcessor.java:114)
at org.eclipse.jface.internal.MenuManagerEventHelper.showEventPostHelper(MenuManagerEventHelper.java:95)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:469)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:463)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:495)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:259)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4209)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1043)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1067)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1048)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java:5157)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4789)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1480)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2263)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4930)
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:237)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:4067)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3620)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1157)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:156)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:152)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:654)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1462)
Caused by: org.eclipse.swt.SWTException: i/o error (java.io.FileNotFoundException: C:\Git\mingw64\share\git\git-for-windows.ico (系統找不到指定的路徑。))
at org.eclipse.swt.SWT.error(SWT.java:4893)
at org.eclipse.swt.SWT.error(SWT.java:4808)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:184)
at org.eclipse.tm.terminal.view.ui.local.showin.ExternalExecutablesUtils.loadImage(ExternalExecutablesUtils.java:38)
at org.eclipse.tm.terminal.view.ui.local.showin.DynamicContributionItems.getContributionItems(DynamicContributionItems.java:74)
at org.eclipse.ui.actions.CompoundContributionItem.getContributionItemsToFill(CompoundContributionItem.java:83)
at org.eclipse.ui.actions.CompoundContributionItem.fill(CompoundContributionItem.java:57)
at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java:146)
at org.eclipse.jface.action.MenuManager.doItemFill(MenuManager.java:729)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:806)
at org.eclipse.jface.action.MenuManager.update(MenuManager.java:673)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.scheduleManagerUpdate(MenuManagerRenderer.java:1227)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.subscribeUIElementTopicVisible(MenuManagerRenderer.java:213)
at jdk.internal.reflect.GeneratedMethodAccessor35.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
... 63 more
Caused by: java.io.FileNotFoundException: C:\Git\mingw64\share\git\git-for-windows.ico (系統找不到指定的路徑。)
at java.base/java.io.FileInputStream.open0(Native Method)
at java.base/java.io.FileInputStream.open(Unknown Source)
at java.base/java.io.FileInputStream.<init>(Unknown Source)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:181)
... 77 more
504 次查看
VaneB
Hi @CY9
Sorry about that, I shared the wrong location. The settings I mentioned previously cannot be edited. Instead, please go to:
Window → Preferences → Terminal → Local Terminal and check the "Show In..." Custom Entries section.
This is where you can look for Git paths.
4 回复数
528 次查看
VaneB
Hi @CY9
As shown in the error message, S32DS is unable to find the git-for-windows.ico in the configured locations. Try pointing to the correct path on your system. To do this, navigate to:
Window → Preferences → Team → Git → Configuration → System Settings
Then update the location so that it matches the actual installation path on your machine.
BR, VaneB
516 次查看
CY9
I can *NOT* find any `C:\Git\...` exist. !?
505 次查看
VaneB
Hi @CY9
497 次查看
CY9
Correct !
It's empty path here :
[Edit]
~case closed~
%3CLINGO-SUB%20id%3D%22lingo-sub-2406448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5BS32DS%5D%20eclipse%20-%20java.io.FileNotFoundException%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EC%3A%5C%20%E7%9B%AE%E5%BD%95%E4%B8%8B%E6%B2%A1%E6%9C%89%E5%90%8D%E4%B8%BA%20%60git%60%20%E7%9A%84%E6%96%87%E4%BB%B6%E5%A4%B9%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%20%60git-for-windows.ico%60%E6%96%87%E4%BB%B6%E4%BD%8D%E4%BA%8E%20D%3A%5Cmsys64%5Cmingw64%5Cshare%5Cgit%5Cgit-for-windows.ico%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AF%8F%E6%AC%A1%E6%88%91%E7%BC%96%E8%AF%91%E4%B8%9C%E8%A5%BF%E7%9A%84%E6%97%B6%E5%80%99%EF%BC%8C%E5%AE%83%E9%83%BD%E4%BC%9A%E5%BC%B9%E5%87%BA%E6%9D%A5%E3%80%82%3C%2FP%3E%3CP%3E%E7%9C%9F%E7%83%A6%E4%BA%BA%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787121511238.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787121511238.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787121511238.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787121511238.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394919iFCE07D0F8332EC2F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787121511238.png%22%20alt%3D%22CY9_0-1787121511238.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787121511238.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787121511238.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787121511238.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E--%3C%2FP%3E%3CDIV%3Eorg.eclipse.e4.core.di.InjectionException%3A%20org.eclipse.swt.SWTException%3A%20i%2Fo%20error%20(java.io.FileNotFoundException%3A%20%3CU%3E%3CSTRONG%3EC%3A%5CGit%5Cmingw64%5Cshare%5Cgit%5Cgit-for-windows.ico%3C%2FSTRONG%3E%3C%2FU%3E%20(%E7%B3%BB%E7%BB%9F%E6%89%BE%E4%B8%8D%E5%88%B0%E6%8C%87%E5%AE%9A%E7%9A%84%E8%B7%AF%E5%BE%84%E3%80%82))%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java%3A68)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java%3A236)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java%3A133)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Display.syncExec(Display.java%3A4742)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.workbench.swt.DisplayUISynchronize.syncExec(DisplayUISynchronize.java%3A34)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.internal.di.UIEventObjectSupplier%24UIEventHandler.handleEvent(UIEventObjectSupplier.java%3A64)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java%3A205)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java%3A203)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java%3A1)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java%3A234)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java%3A151)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java%3A133)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java%3A75)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java%3A44)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java%3A55)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java%3A63)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java%3A424)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setVisible(UIElementImpl.java%3A361)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.workbench.renderers.swt.ContributionRecord.updateVisibility(ContributionRecord.java%3A113)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java%3A191)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java%3A202)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.showMenu(MenuManagerShowProcessor.java%3A256)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.menuAboutToHide(MenuManagerShowProcessor.java%3A114)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.jface.internal.MenuManagerEventHelper.showEventPostHelper(MenuManagerEventHelper.java%3A95)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java%3A469)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.jface.action.MenuManager.access%241(MenuManager.java%3A463)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.jface.action.MenuManager%242.menuShown(MenuManager.java%3A495)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java%3A259)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java%3A89)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Display.sendEvent(Display.java%3A4209)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Widget.sendEvent(Widget.java%3A1043)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Widget.sendEvent(Widget.java%3A1067)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Widget.sendEvent(Widget.java%3A1048)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.java%3A5157)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Control.windowProc(Control.java%3A4789)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java%3A340)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java%3A1480)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Shell.windowProc(Shell.java%3A2263)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Display.windowProc(Display.java%3A4930)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.internal.win32.OS.TrackPopupMenu(%E6%9C%AC%E5%9C%B0%E6%96%B9%E6%B3%95)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Menu._setVisible(Menu.java%3A237)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Display.runPopups(Display.java%3A4067)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.widgets.Display.readAndDispatch(Display.java%3A3620)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine%245.run(PartRenderingEngine.java%3A1157)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java%3A338)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java%3A1046)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java%3A155)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.ui.internal.Workbench.lambda%243(Workbench.java%3A644)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java%3A338)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java%3A551)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java%3A156)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java%3A152)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java%3A203)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java%3A134)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java%3A104)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java%3A401)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java%3A255)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20java.base%2Fjdk.internal.reflect.NativeMethodAccessorImpl.invoke0(%E6%9C%AC%E5%9C%B0%E6%96%B9%E6%B3%95)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20java.base%2Fjdk.internal.reflect.NativeMethodAccessorImpl.invoke(%E6%9C%AA%E7%9F%A5%E6%BA%90)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20java.base%2Fjdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(%E6%9C%AA%E7%9F%A5%E6%9D%A5%E6%BA%90%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20java.base%2Fjava.lang.reflect.Method.invoke(%E6%9C%AA%E7%9F%A5%E6%9D%A5%E6%BA%90%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.equinox.launcher.Main.invokeFramework(Main.java%3A654)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.equinox.launcher.Main.basicRun(Main.java%3A591)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.equinox.launcher.Main.run(Main.java%3A1462)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E5%BC%95%E8%B5%B7%EF%BC%9Aorg.eclipse.swt.SWTException%3A%20i%2Fo%20error%20(java.io.FileNotFoundException%3A%20C%3A%5CGit%5Cmingw64%5Cshare%5Cgit%5Cgit-for-windows.ico%20(%E7%B3%BB%E7%BB%9F%E6%89%BE%E4%B8%8D%E5%88%B0%E6%8C%87%E5%AE%9A%E7%9A%84%E8%B7%AF%E5%BE%84%E3%80%82))%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.SWT.error(SWT.java%3A4893)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.SWT.error(SWT.java%3A4808)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java%3A184)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.tm.terminal.view.ui.local.showin.ExternalExecutablesUtils.loadImage(ExternalExecutablesUtils.java%3A38)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.tm.terminal.view.ui.local.showin.DynamicContributionItems.getContributionItems(DynamicContributionItems.java%3A74)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.ui.actions.CompoundContributionItem.getContributionItemsToFill(CompoundContributionItem.java%3A83)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.ui.actions.CompoundContributionItem.fill(CompoundContributionItem.java%3A57)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java%3A146)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.jface.action.MenuManager.doItemFill(MenuManager.java%3A729)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.jface.action.MenuManager.update(MenuManager.java%3A806)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.jface.action.MenuManager.update(MenuManager.java%3A673)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.scheduleManagerUpdate(MenuManagerRenderer.java%3A1227)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer.subscribeUIElementTopicVisible(MenuManagerRenderer.java%3A213)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20jdk.internal.reflect.GeneratedMethodAccessor35.invoke(%E6%9C%AA%E7%9F%A5%E6%9D%A5%E6%BA%90%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20java.base%2Fjdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(%E6%9C%AA%E7%9F%A5%E6%9D%A5%E6%BA%90%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20java.base%2Fjava.lang.reflect.Method.invoke(%E6%9C%AA%E7%9F%A5%E6%9D%A5%E6%BA%90%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java%3A58)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%BF%98%E6%9C%89%2063%20%E4%B8%AA%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3ECaused%20by%3A%20java.io.FileNotFoundException%3A%20C%3A%5CGit%5Cmingw64%5Cshare%5Cgit%5Cgit-for-windows.ico%20(%E7%B3%BB%E7%BB%9F%E6%89%BE%E4%B8%8D%E5%88%B0%E6%8C%87%E5%AE%9A%E7%9A%84%E8%B7%AF%E5%BE%84%E3%80%82)%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20java.base%2Fjava.io.FileInputStream.open0(Native%E6%96%B9%E6%B3%95%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20java.base%2Fjava.io.FileInputStream.open(%E6%9C%AA%E7%9F%A5%E6%9D%A5%E6%BA%90%EF%BC%89%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20java.base%2Fjava.io.FileInputStream.%3CINIT%3E(%E6%9C%AA%E7%9F%A5)%E6%9D%A5%E6%BA%90%EF%BC%89%3C%2FINIT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20java.base%2Fjava.io.FileInputStream.%3CINIT%3E(%E6%9C%AA%E7%9F%A5)%E6%9D%A5%E6%BA%90%EF%BC%89%3C%2FINIT%3E%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%9C%A8%20org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java%3A181)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E8%BF%98%E6%9C%8977%E4%B8%AA%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32DS%5D%20eclipse%20-%20java.io.FileNotFoundException%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%20%60C%3A%5CGit%5C...%60%20%E6%96%87%E4%BB%B6%E3%80%82%EF%BC%81%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787192155321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787192155321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787192155321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787192155321.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394979iA8FA475870D2252F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787192155321.png%22%20alt%3D%22CY9_0-1787192155321.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787192155321.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787192155321.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787192155321.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2406713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32DS%5D%20eclipse%20-%20java.io.FileNotFoundException%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2406713%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225755%22%20target%3D%22_blank%22%3E%40CY9%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E6%89%80%E7%A4%BA%EF%BC%8CS32DS%20%E6%97%A0%E6%B3%95%E5%9C%A8%E9%85%8D%E7%BD%AE%E7%9A%84%E4%BD%8D%E7%BD%AE%E6%89%BE%E5%88%B0%20git-for-windows.ico%E3%80%82%E8%AF%B7%E5%B0%9D%E8%AF%95%E5%9C%A8%E7%B3%BB%E7%BB%9F%E4%B8%AD%E6%8C%87%E5%90%91%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%B7%AF%E5%BE%84%E3%80%82%E4%B8%BA%E6%AD%A4%EF%BC%8C%E8%AF%B7%E5%AF%BC%E8%88%AA%E8%87%B3%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E7%AA%97%E5%8F%A3%20%E2%86%92%20%E9%A6%96%E9%80%89%E9%A1%B9%20%E2%86%92%20%E5%9B%A2%E9%98%9F%20%E2%86%92%20Git%20%E2%86%92%20%E9%85%8D%E7%BD%AE%20%E2%86%92%20%E7%B3%BB%E7%BB%9F%E8%AE%BE%E7%BD%AE%3C%2FP%3E%0A%3CP%3E%E7%84%B6%E5%90%8E%E6%9B%B4%E6%96%B0%E4%BD%8D%E7%BD%AE%EF%BC%8C%E4%BD%BF%E5%85%B6%E4%B8%8E%E6%82%A8%E8%AE%A1%E7%AE%97%E6%9C%BA%E4%B8%8A%E7%9A%84%E5%AE%9E%E9%99%85%E5%AE%89%E8%A3%85%E8%B7%AF%E5%BE%84%E7%9B%B8%E5%8C%B9%E9%85%8D%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%EF%BC%8CVaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2407085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32DS%5D%20eclipse%20-%20java.io.FileNotFoundException%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407085%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225755%22%20target%3D%22_blank%22%3E%40CY9%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E6%88%91%E5%88%86%E4%BA%AB%E9%94%99%E4%BA%86%E5%9C%B0%E7%82%B9%E3%80%82%E6%88%91%E4%B9%8B%E5%89%8D%E6%8F%90%E5%88%B0%E7%9A%84%E8%AE%BE%E7%BD%AE%E6%97%A0%E6%B3%95%E7%BC%96%E8%BE%91%E3%80%82%E8%AF%B7%E6%94%B9%E7%94%A8%E4%BB%A5%E4%B8%8B%E6%96%B9%E5%BC%8F%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E6%89%93%E5%BC%80%E2%80%9C%E7%AA%97%E5%8F%A3%E2%80%9D%E2%86%92%E2%80%9C%E9%A6%96%E9%80%89%E9%A1%B9%E2%80%9D%E2%86%92%E2%80%9C%E7%BB%88%E7%AB%AF%E2%80%9D%E2%86%92%E2%80%9C%E6%9C%AC%E5%9C%B0%E7%BB%88%E7%AB%AF%E2%80%9D%EF%BC%8C%E5%8B%BE%E9%80%89%E2%80%9C%E6%98%BE%E7%A4%BA%E5%9C%A8...%E2%80%9D%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%A1%E7%9B%AE%E9%83%A8%E5%88%86%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E8%BF%99%E9%87%8C%E6%9F%A5%E6%89%BE%20Git%20%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2407140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32DS%5D%20eclipse%20-%20java.io.FileNotFoundException%20!%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2407140%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%AD%A3%E7%A1%AE%E7%9A%84%20%EF%BC%81%20%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E9%87%8C%E6%98%AF%E4%B8%80%E6%9D%A1%E7%A9%BA%E8%B7%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_0-1787269588821.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_0-1787269588821.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395061i13B1CDE74ECB9FF8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_0-1787269588821.png%22%20alt%3D%22CY9_0-1787269588821.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_0-1787269588821.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%5B%E7%BC%96%E8%BE%91%5D%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22CY9_1-1787269614644.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22CY9_1-1787269614644.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F395062i9CFEEC3F0A41F54D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22CY9_1-1787269614644.png%22%20alt%3D%22CY9_1-1787269614644.png%22%20%2F%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ECY9_1-1787269614644.png%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%A1%88%E4%BB%B6%E5%B7%B2%E7%BB%93%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
