S32DS can not launch
961 次查看
alice_th
before i can use S32DS, but today I can't launch S32DS IDE, attached is log file
could you help to check it.
948 次查看
jiri_kral
the last entry in the log file is from December 4 - means that the log file is not actual and is not written because the starting process of S32DS get stuck.
You can try to re-install S32DS.
