S32DS PA2.1 Activation error Online & Offline
lizhichaosdut
offline activation.xml:
<?xml version="1.0" encoding="UTF-8" ?><Response xmlns="http://www.macrovision.com/fnp/2004/11/activation"><ResponseHeader><VersionNumber>1</VersionNumber><ResponseType>FAILURE</ResponseType><RequestSequenceNumber>51</RequestSequenceNumber><RequestHash>D27BC7D0E1BE578E178E8520E79610AABEB4CFAA</RequestHash></ResponseHeader><ResponseData><ResponseReason>ERROR</ResponseReason><ErrorCode>com.acresso.activation.handler.ServerException</ErrorCode></ResponseData><Signature>E6149CE0B3BCF57D103D4ED2CA2911BC8329295B</Signature><SignatureVersion>1</SignatureVersion></Response>
online:
Mehul_Patel_NXP
Hi, @lizhichaosdut ,
Please can you follow the below troubleshooting guide for 2nd case (com.acresso.activation.handler.ServerException)
: https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/Troubleshooting-Activation-fails-with-...
Please try the solution steps and reply us back if the solution worked.
Thank you. Best regards,
- Mehul Patel
Mehul_Patel_NXP
As I am checking your activation request it is unable to get the unique machine number which should be attached to the PC.
it seems either you are using non-persistent virtual machine, if it is not the case, if may be the issue with flexnet publisher version is different or creating some issue, while you are migrating to the new PC. You can check the below troubleshooting guide in the case:
Please let us know if the any update on the issue.
Thank you. Kind regards.
- Mehul Patel
Mehul_Patel_NXP
- Mehul Patel
Mehul_Patel_NXP
Is this issue is resolved, please let us know the issue still persists.
Thank you. Kind regard.
- Mehul Patel
lizhichaosdut
SPC5 studio is my another choice
lizhichaosdut
no. and I don't want to try after waste lot of time. re install OS will be okay.
other 2 pc are OK.
thanks
