S32DS IDE: CMake project Debug
Bruce_Ye
hello,
I am using cmake+nijia to create ELF files instead of S32DS IDE. The target development board is S32K344, and the compiler is GHS.
I have successfully generated ELF files so far, but when using PE for ELF file debugging, it does not work as expected, such as the Step over and Step return functions.
Here is the CMake project configuration I am using
***********************************CompileCfg.cmake**************************************
# Basic Settings
set(CMAKE_SYSTEM_NAME Generic)
set(CMAKE_SYSTEM_PROCESSOR ARM)
# Set up compiler
set(CMAKE_ASM_COMPILER "D:/D/tools/ghs/comp_202114/ccarm.exe")
set(CMAKE_C_COMPILER "D:/D/tools/ghs/comp_202114/ccarm.exe")
set(CMAKE_LINKER "D:/D/tools/ghs/comp_202114/ccarm.exe")
set(CMAKE_AR "D:/D/tools/ghs/comp_202114/ccarm.exe")
# Set compilation link options
set(C_OPTIONS "-preprocess_assembly_files -c99 --gnu_asm -g -dwarf2 -Onone -DSTART_FROM_FLASH -DS32K3XX -DENABLE_FPU -DLTC_ISOFT_CUSTOM -DINIT_STDBY_RAM -DARMCM7_SP -D__ITCM_INIT -D__DTCM_INIT -D__ghs__  -DGEELY_SPECIFICATION_USED=1 -DDISABLE_MCAL_INTERMODULE_ASR_CHECK -DBTB_ENABLE -DUSING_OS_AUTOSAROS -DS32K344 -DGHS -cpu=cortexm7 -fsingle -thumb -MD")
set(ASM_OPTIONS ${C_OPTIONS})
set(LD_OPTIONS "--gnu_asm -g -dwarf2 -nostartfiles -cpu=cortexm7 -thumb")
set(CMAKE_C_FLAGS ${C_OPTIONS})
set(CMAKE_ASM_FLAGS ${ASM_OPTIONS})
set(CMAKE_EXE_LINKER_FLAGS ${LD_OPTIONS})
set(CMAKE_TRY_COMPILE_PLATFORM_VARIABLES CMAKE_C_FLAGS CMAKE_ASM_FLAGS)
set(CMAKE_FIND_ROOT_PATH ${BINUTILS_PATH})
set(CMAKE_FIND_ROOT_PATH_MODE_PROGRAM NEVER)
set(CMAKE_FIND_ROOT_PATH_MODE_LIBRARY ONLY)
set(CMAKE_FIND_ROOT_PATH_MODE_INCLUDE ONLY)
******************************************CMakeLists.txt***********************************************
set(target_name "S32K344")
# Contains compile link configuration/lookup function cmake file
include(./CompileCfg.cmake)
include(./Function.cmake)
cmake_minimum_required(VERSION 3.5 FATAL_ERROR)
# Set project name and language
project(${target_name}_prj LANGUAGES C ASM)
# Set C language standard
set(CMAKE_C_STANDARD 99) # C99标准
set(CMAKE_C_EXTENSIONS ON) # 开启扩展,开启编译器特有扩展
set(CMAKE_C_STANDARD_REQUIRED ON) #强制指定标准
# Set engineering/OS src path
set(OS_SRC_DIR "${CA_DIR}/01_ProductCode/RTOS")
set(PRJ_SRC_DIR "${CA_DIR}/02_ProjectCode/00_OS_Project/${target_name}_CMake/src")
# Set link script file
set(LINK_SCRIPTS
    --gnu_asm
    -g
    -dwarf2
    -T "../src/McalLib/Mcal_lib/Platform_TS_T40D34M10I0R0/build_files/ghs/linker_flash_s32k344.ld"
    -e Reset_Handler
    -nostartfiles
    -cpu=cortexm7
    -thumb
# Set CommmonInclude header file directory
set(PRJ_COMMMONINCLUDE_INCS "${PRJ_SRC_DIR}/CommmonInclude")
# Contains cmake files corresponding to each module
include(${OS_SRC_DIR}/Os.cmake)
include(${PRJ_SRC_DIR}/McalLib/Mcal.cmake)
include(${PRJ_SRC_DIR}/Generate/Generate.cmake)
# Project Add Header File Dependency
include_directories(${PRJ_COMMMONINCLUDE_INCS} ${PRJ_GENERATE_INCS} ${BSW_OS_INCS} ${PRJ_SOURCE_INCS})
# get_property(dirs DIRECTORY ${CMAKE_SOURCE_DIR} PROPERTY INCLUDE_DIRECTORIES)
# message(">>> include_dirs=${dirs}")
# Set output file
set(EXECUTABLE ${target_name}.elf CACHE INTERNAL "TARGET")
# Obtain user files and build them
file(GLOB PRJ_MAIN_SRCS "${PRJ_SRC_DIR}/*.c")
add_executable(${EXECUTABLE} ${PRJ_MAIN_SRCS})
# Introduce subdirectories and build them
target_sources(${EXECUTABLE} PUBLIC ${PRJ_MCAL_SRCS})
target_sources(${EXECUTABLE} PUBLIC ${PRJ_GENERATE_SRCS})
target_sources(${EXECUTABLE} PUBLIC ${BSW_OS_SRCS})
# Special processing of assembly files
list(APPEND CMAKE_ASM_SOURCE_FILE_EXTENSIONS S asm inc)
set(MCAL_ASM_PATH "${PRJ_SRC_DIR}/McalLib/Mcal_lib/Platform_TS_T40D34M10I0R0/startup/src/m7/ghs")
set(SAM_OBJ "${OS_SRC_DIR}/Platform/S32K3/S32K344/Arch_PendSV.s" "${MCAL_ASM_PATH}/startup_cm7.s" "${MCAL_ASM_PATH}/Vector_Table.s")
SET_SOURCE_FILES_PROPERTIES(${SAM_OBJ} PROPERTIES LANGUAGE ASM)
target_sources(${EXECUTABLE} PUBLIC ${SAM_OBJ})
# Link Options
target_link_options(${EXECUTABLE} PRIVATE  ${LINK_SCRIPTS})
How to use IDE debugging correctly,
Kind Regards.
stanish
This issue is probably related to a known issue listed in the S32DS release notes:
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/S32-Design-Studio-for-S32-Platform-v3-...
Step out work incorrect with dbg_derived_types source: The GHS toolchain does not
generate DWARF Call Frame information that is suitable for unwinding the call stack. For
third-party debuggers incapable of unwinding the call stack through an alternate means
(disassembling code), this may nullify the ability to walk the call stack or view variables saved
in previous frames. As a workaround S32DS removes the debug frames info to force GDB client
to recreate the frames. In some cases this method may not work and lead to incorrect behaviour
for Step out command.
Workaround: Set a breakpoint at function end and run to breakpoint
Similar issue was pressent in S32DS for arm/power:
Problems could be experienced while debugging of elf file generated by GHS compiler like
missing call stack information, incorrect info on step into function, etc.
Workaround: On occasion GHS generates GDB incompatible debug information preventing the
debugger from displaying the call stack. In some cases, without such information gdb can still
debug your program. The program build needs to be augmented with a post-build step, select the
project in the project explorer view and File->Properties to display the project properties, under
C/C++ Build -> Settings select the build steps tab and enter the command gstrip –
r=.debug_frame executable. Switch to Instruction Stepping Mode to be able to step through
function. If this workaround does not help – please report issue to GreenHills support.
Hope it helps.
Stan
kdscrr
@Bruce_Ye  hello, may I ask you a question?
how to import the source code into the S32DS ide?
when I import the elf which is generated by ghs into S32DS, but when I download the elf into MCU, I can not see the source code , only see the assembly code?
thanks
Bruce_Ye
The following is the engineering log of IDE using the GHS compiler:
Finished building: ../src/main.c
Building file: ../Projectcode/Mcal_config/src/Clock_Ip_Cfg.c
Invoking: GHS C Compiler for ARM Standalone
ccarm -preprocess_assembly_files -c99 --gnu_asm -g -dwarf2 -Onone -DSTART_FROM_FLASH -DS32K3XX -DENABLE_FPU -DLTC_ISOFT_CUSTOM -DINIT_STDBY_RAM -DARMCM7_SP -D__ITCM_INIT -D__DTCM_INIT -D__ghs__ -DGEELY_SPECIFICATION_USED=1 -DDISABLE_MCAL_INTERMODULE_ASR_CHECK -DBTB_ENABLE -DUSING_OS_AUTOSAROS -DS32K344 -DGHS -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Extend" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\CommonInclude" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Kernel" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Platform" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\BSW_Config" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Base_TS_T40D34M10I0R0" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Base_TS_T40D34M10I0R0\header" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Base_TS_T40D34M10I0R0\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Base_TS_T40D34M10I0R0\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Det_TS_T40D34M10I0R0" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Det_TS_T40D34M10I0R0\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Det_TS_T40D34M10I0R0\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Mcu_TS_T40D34M10I0R0" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Mcu_TS_T40D34M10I0R0\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Mcu_TS_T40D34M10I0R0\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\build_files" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\build_files\ghs" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\startup" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\startup\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\startup\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\startup\src\m7" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Platform_TS_T40D34M10I0R0\startup\src\m7\ghs" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Rte_TS_T40D34M10I0R0" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Rte_TS_T40D34M10I0R0\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal\Rte_TS_T40D34M10I0R0\src" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal_config" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal_config\include" -I"D:\D\workpalce\S32k344\S32K344_DEMO_20\Projectcode\Mcal_config\src" -cpu=cortexm7 -fsingle -thumb -MD -c -o "Projectcode/Mcal_config/src/Clock_Ip_Cfg.o" "../Projectcode/Mcal_config/src/Clock_Ip_Cfg.c"
"D:\D\workpalce\S32k344\S32K344_DEMO_20\Platform\Arch_Define.h", line 66: warning #1-D:
last line of file ends without a newline
/*=======[E N D O F F I L E]==============================================*/
Finished building: ../Projectcode/Mcal_config/src/Clock_Ip_Cfg.c
Building target: S32K344_DEMO_20.elf
Invoking: GHS C Linker for ARM Standalone
ccarm --gnu_asm -g -dwarf2 -T "D:/D/workpalce/S32k344/S32K344_DEMO_20/Projectcode/Mcal/Platform_TS_T40D34M10I0R0/build_files/ghs/linker_flash_s32k344.ld" -e Reset_Handler -nostartfiles -cpu=cortexm7 -thumb -o "S32K344_DEMO_20.elf" ./src/main.o ./Projectcode/Mcal_config/src/Clock_Ip_Cfg.o ./Projectcode/Mcal_config/src/Clock_Ip_PBcfg.o ./Projectcode/Mcal_config/src/IntCtrl_Ip_Cfg.o ./Projectcode/Mcal_config/src/Mcu_Cfg.o ./Projectcode/Mcal_config/src/Mcu_PBcfg.o ./Projectcode/Mcal_config/src/OsIf_Cfg.o ./Projectcode/Mcal_config/src/Platform_Cfg.o ./Projectcode/Mcal_config/src/Platform_Ipw_Cfg.o ./Projectcode/Mcal_config/src/Power_Ip_Cfg.o ./Projectcode/Mcal_config/src/Power_Ip_PBcfg.o ./Projectcode/Mcal_config/src/Ram_Ip_Cfg.o ./Projectcode/Mcal_config/src/Ram_Ip_PBcfg.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Adc.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Can.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Crc.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Crypto.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Dio.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Eth.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_EthSwt_43_SJA11XX.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_EthTrcv_43_PHY.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Fee.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Fls.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Gpt.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_I2c.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_I3c.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Icu.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Iseled.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Lin.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Mcl.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Mcu.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Ocu.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Port.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Pwm.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Rm.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Sai.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Sbc_fs26.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Sbc_fs86.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Sent.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Spi.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Uart.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Wdg.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Wdg_43_fs26.o ./Projectcode/Mcal/Rte_TS_T40D34M10I0R0/src/SchM_Wdg_43_fs86.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/m7/ghs/Vector_Table.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/m7/ghs/startup_cm7.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/m7/exceptions.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/m7/startup.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/nvic.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/sys_init.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/startup/src/system.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/src/IntCtrl_Ip.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/src/Platform.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/src/Platform_Ipw.o ./Projectcode/Mcal/Platform_TS_T40D34M10I0R0/src/System_Ip.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Data.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Divider.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_DividerTrigger.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_ExtOsc.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_FracDiv.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Frequency.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Gate.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_IntOsc.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Irq.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Monitor.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Pll.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_ProgFreqSwitch.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Selector.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Clock_Ip_Specific.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Mcu.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Mcu_Dem_Wrapper.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Mcu_Ipw.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_CortexM7.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_FLASH.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_MC_ME.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_MC_RGM.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_MC_RGM_Irq.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_PMC.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_PMC_Irq.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Power_Ip_Private.o ./Projectcode/Mcal/Mcu_TS_T40D34M10I0R0/src/Ram_Ip.o ./Projectcode/Mcal/Det_TS_T40D34M10I0R0/src/Det.o ./Projectcode/Mcal/Det_TS_T40D34M10I0R0/src/Det_stub.o ./Projectcode/Mcal/Base_TS_T40D34M10I0R0/src/OsIf_Timer.o ./Projectcode/Mcal/Base_TS_T40D34M10I0R0/src/OsIf_Timer_System.o ./Projectcode/Mcal/Base_TS_T40D34M10I0R0/src/OsIf_Timer_System_Internal_Systick.o ./Projectcode/BSW_Config/Os_Cfg.o ./Projectcode/BSW_Config/Os_Intvet.o ./Projectcode/BSW_Config/Os_Kdata.o ./Projectcode/BSW_Config/Os_UserInf.o ./Platform/Arch_Extend.o ./Platform/Arch_Irq.o ./Platform/Arch_Mpu.o ./Platform/Arch_PendSV.o ./Platform/Arch_Processor.o ./Platform/Arch_Timer.o ./Platform/Arch_Trap.o ./Kernel/Os_Alarm.o ./Kernel/Os_Appl.o ./Kernel/Os_Core.o ./Kernel/Os_Counter.o ./Kernel/Os_Event.o ./Kernel/Os_Hook.o ./Kernel/Os_Interrupt.o ./Kernel/Os_Ioc.o ./Kernel/Os_Kernel.o ./Kernel/Os_Mprot.o ./Kernel/Os_Panic.o ./Kernel/Os_Peripheral.o ./Kernel/Os_Resource.o ./Kernel/Os_Rpc.o ./Kernel/Os_ScheduleTable.o ./Kernel/Os_Spinlock.o ./Kernel/Os_Sprot.o ./Kernel/Os_StackMonitor.o ./Kernel/Os_Task.o ./Kernel/Os_Tprot.o ./Extend/Os_Extend.o
Finished building target: S32K344_DEMO_20.elf
stanish
Hope it helps.
Stan
Bruce_Ye
Thank you for your help.
"Problems could be experienced while debugging of elf file generated by GHS compiler like
missing call stack information, incorrect info on step into function, etc.". It is indeed here that caused the problem. I encountered the same issue during debugging when deleting gstrip - r=. debug_frame ${ProjName}. elf in the S32DS compiled project.
Next, I need to add relevant commands to my CMakeLists.txt. I hope everything goes smoothly.
%3CLINGO-SUB%20id%3D%22lingo-sub-1789405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32DS%20IDE%3A%20CMake%20project%20Debug%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1789405%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ehello%EF%BC%8C%3C%2FP%3E%3CP%3EI%20am%20using%20cmake%2Bnijia%20to%20create%20ELF%20files%20instead%20of%20S32DS%20IDE.%20The%20target%20development%20board%20is%20S32K344%2C%20and%20the%20compiler%20is%20GHS.%3C%2FP%3E%3CP%3EI%20have%20successfully%20generated%20ELF%20files%20so%20far%2C%20but%20when%20using%20PE%20for%20ELF%20file%20debugging%2C%20it%20does%20not%20work%20as%20expected%2C%20such%20as%20the%20Step%20over%20and%20Step%20return%20functions.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Bruce_Ye_0-1705396720058.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bruce_Ye_0-1705396720058.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F258351iB474A20F56F0BCE1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Bruce_Ye_0-1705396720058.png%22%20alt%3D%22Bruce_Ye_0-1705396720058.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EBruce_Ye_0-1705396720058.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EHere%20is%20the%20CMake%20project%20configuration%20I%20am%20using%3C%2FP%3E%3CP%3E***********************************CompileCfg.cmake**************************************%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%23%20Basic%20Settings%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_SYSTEM_NAME%20Generic)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_SYSTEM_PROCESSOR%20ARM)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Set%20up%20compiler%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_ASM_COMPILER%20%3C%2FSPAN%3E%3CSPAN%3E%22D%3A%2FD%2Ftools%2Fghs%2Fcomp_202114%2Fccarm.exe%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_C_COMPILER%20%3C%2FSPAN%3E%3CSPAN%3E%22D%3A%2FD%2Ftools%2Fghs%2Fcomp_202114%2Fccarm.exe%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_LINKER%20%3C%2FSPAN%3E%3CSPAN%3E%22D%3A%2FD%2Ftools%2Fghs%2Fcomp_202114%2Fccarm.exe%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ECMAKE_AR%3C%2FSPAN%3E%20%3CSPAN%3E%22D%3A%2FD%2Ftools%2Fghs%2Fcomp_202114%2Fccarm.exe%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Set%20compilation%20link%20options%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(C_OPTIONS%20%3C%2FSPAN%3E%3CSPAN%3E%22-preprocess_assembly_files%20-c99%20--gnu_asm%20-g%20-dwarf2%20-Onone%20-DSTART_FROM_FLASH%20-DS32K3XX%20-DENABLE_FPU%20-DLTC_ISOFT_CUSTOM%20-DINIT_STDBY_RAM%20-DARMCM7_SP%20-D__ITCM_INIT%20-D__DTCM_INIT%20-D__ghs__%20%26nbsp%3B-DGEELY_SPECIFICATION_USED%3D1%20-DDISABLE_MCAL_INTERMODULE_ASR_CHECK%20-DBTB_ENABLE%20-DUSING_OS_AUTOSAROS%20-DS32K344%20-DGHS%20-cpu%3Dcortexm7%20-fsingle%20-thumb%20-MD%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(ASM_OPTIONS%20%3C%2FSPAN%3E%3CSPAN%3E%24%7BC_OPTIONS%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(LD_OPTIONS%20%3C%2FSPAN%3E%3CSPAN%3E%22--gnu_asm%20-g%20-dwarf2%20-nostartfiles%20-cpu%3Dcortexm7%20-thumb%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_C_FLAGS%20%3C%2FSPAN%3E%3CSPAN%3E%24%7BC_OPTIONS%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_ASM_FLAGS%20%3C%2FSPAN%3E%3CSPAN%3E%24%7BASM_OPTIONS%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3ECMAKE_EXE_LINKER_FLAGS%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BLD_OPTIONS%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_TRY_COMPILE_PLATFORM_VARIABLES%20CMAKE_C_FLAGS%20CMAKE_ASM_FLAGS)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_FIND_ROOT_PATH%20%3C%2FSPAN%3E%3CSPAN%3E%24%7BBINUTILS_PATH%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_FIND_ROOT_PATH_MODE_PROGRAM%20NEVER)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_FIND_ROOT_PATH_MODE_LIBRARY%20ONLY)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_FIND_ROOT_PATH_MODE_INCLUDE%20ONLY)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E******************************************CMakeLists.txt***********************************************%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(target_name%20%3C%2FSPAN%3E%3CSPAN%3E%22S32K344%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Contains%20compile%20link%20configuration%2Flookup%20function%20cmake%20file%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einclude%3C%2FSPAN%3E%3CSPAN%3E(.%2FCompileCfg.cmake)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einclude%3C%2FSPAN%3E%3CSPAN%3E(.%2FFunction.cmake)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Ecmake_minimum_required%3C%2FSPAN%3E%3CSPAN%3E(VERSION%203.5%20FATAL_ERROR)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Set%20project%20name%20and%20language%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eproject%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7Btarget_name%7D%3C%2FSPAN%3E%3CSPAN%3E_prj%20LANGUAGES%20C%20ASM)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Set%20C%20language%20standard%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_C_STANDARD%2099)%20%3C%2FSPAN%3E%3CSPAN%3E%23%20C99%E6%A0%87%E5%87%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_C_EXTENSIONS%20%3C%2FSPAN%3E%3CSPAN%3EON%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%23%20%E5%BC%80%E5%90%AF%E6%89%A9%E5%B1%95%EF%BC%8C%E5%BC%80%E5%90%AF%E7%BC%96%E8%AF%91%E5%99%A8%E7%89%B9%E6%9C%89%E6%89%A9%E5%B1%95%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(CMAKE_C_STANDARD_REQUIRED%20%3C%2FSPAN%3E%3CSPAN%3EON%3C%2FSPAN%3E%3CSPAN%3E)%20%3C%2FSPAN%3E%3CSPAN%3E%23%E5%BC%BA%E5%88%B6%E6%8C%87%E5%AE%9A%E6%A0%87%E5%87%86%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Set%20engineering%2FOS%20src%20path%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(OS_SRC_DIR%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BCA_DIR%7D%2F01_ProductCode%2FRTOS%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(PRJ_SRC_DIR%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BCA_DIR%7D%2F02_ProjectCode%2F00_OS_Project%2F%24%7Btarget_name%7D_CMake%2Fsrc%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Set%20link%20script%20file%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(LINK_SCRIPTS%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20--gnu_asm%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20-g%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20-dwarf2%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20-T%20%3C%2FSPAN%3E%3CSPAN%3E%22..%2Fsrc%2FMcalLib%2FMcal_lib%2FPlatform_TS_T40D34M10I0R0%2Fbuild_files%2Fghs%2Flinker_flash_s32k344.ld%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20-e%20Reset_Handler%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20-nostartfiles%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20-cpu%3Dcortexm7%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20-thumb%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Set%20CommmonInclude%20header%20file%20directory%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(PRJ_COMMMONINCLUDE_INCS%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BPRJ_SRC_DIR%7D%2FCommmonInclude%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Contains%20cmake%20files%20corresponding%20to%20each%20module%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einclude%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7BOS_SRC_DIR%7D%3C%2FSPAN%3E%3CSPAN%3E%2FOs.cmake)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einclude%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7BPRJ_SRC_DIR%7D%3C%2FSPAN%3E%3CSPAN%3E%2FMcalLib%2FMcal.cmake)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einclude%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7BPRJ_SRC_DIR%7D%3C%2FSPAN%3E%3CSPAN%3E%2FGenerate%2FGenerate.cmake)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Project%20Add%20Header%20File%20Dependency%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Einclude_directories%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7BPRJ_COMMMONINCLUDE_INCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BPRJ_GENERATE_INCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BBSW_OS_INCS%7D%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BPRJ_SOURCE_INCS%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%20get_property(dirs%20DIRECTORY%20%24%7BCMAKE_SOURCE_DIR%7D%20PROPERTY%20INCLUDE_DIRECTORIES)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%23%20message(%22%26gt%3B%26gt%3B%26gt%3B%20include_dirs%3D%24%7Bdirs%7D%22)%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Set%20output%20file%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(EXECUTABLE%20%3C%2FSPAN%3E%3CSPAN%3E%24%7Btarget_name%7D%3C%2FSPAN%3E%3CSPAN%3E.elf%20%3C%2FSPAN%3E%3CSPAN%3ECACHE%3C%2FSPAN%3E%20%3CSPAN%3EINTERNAL%3C%2FSPAN%3E%20%3CSPAN%3E%22TARGET%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Obtain%20user%20files%20and%20build%20them%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Efile%3C%2FSPAN%3E%3CSPAN%3E(GLOB%20PRJ_MAIN_SRCS%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BPRJ_SRC_DIR%7D%2F*.c%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eadd_executable%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7BEXECUTABLE%7D%3C%2FSPAN%3E%20%3CSPAN%3E%24%7BPRJ_MAIN_SRCS%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Introduce%20subdirectories%20and%20build%20them%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Etarget_sources%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7BEXECUTABLE%7D%3C%2FSPAN%3E%3CSPAN%3E%20PUBLIC%20%3C%2FSPAN%3E%3CSPAN%3E%24%7BPRJ_MCAL_SRCS%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Etarget_sources%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7BEXECUTABLE%7D%3C%2FSPAN%3E%3CSPAN%3E%20PUBLIC%20%3C%2FSPAN%3E%3CSPAN%3E%24%7BPRJ_GENERATE_SRCS%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Etarget_sources%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7BEXECUTABLE%7D%3C%2FSPAN%3E%3CSPAN%3E%20PUBLIC%20%3C%2FSPAN%3E%3CSPAN%3E%24%7BBSW_OS_SRCS%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Special%20processing%20of%20assembly%20files%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Elist%3C%2FSPAN%3E%3CSPAN%3E(APPEND%20CMAKE_ASM_SOURCE_FILE_EXTENSIONS%20S%20asm%20inc)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(MCAL_ASM_PATH%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BPRJ_SRC_DIR%7D%2FMcalLib%2FMcal_lib%2FPlatform_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fm7%2Fghs%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Eset%3C%2FSPAN%3E%3CSPAN%3E(SAM_OBJ%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BOS_SRC_DIR%7D%2FPlatform%2FS32K3%2FS32K344%2FArch_PendSV.s%22%3C%2FSPAN%3E%20%3CSPAN%3E%22%24%7BMCAL_ASM_PATH%7D%2Fstartup_cm7.s%22%3C%2FSPAN%3E%20%3CSPAN%3E%22%24%7BMCAL_ASM_PATH%7D%2FVector_Table.s%22%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3ESET_SOURCE_FILES_PROPERTIES%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7BSAM_OBJ%7D%3C%2FSPAN%3E%3CSPAN%3E%20PROPERTIES%20LANGUAGE%20ASM)%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Etarget_sources%3C%2FSPAN%3E%3CSPAN%3E(%3C%2FSPAN%3E%3CSPAN%3E%24%7BEXECUTABLE%7D%3C%2FSPAN%3E%3CSPAN%3E%20PUBLIC%20%3C%2FSPAN%3E%3CSPAN%3E%24%7BSAM_OBJ%7D%3C%2FSPAN%3E%3CSPAN%3E)%3C%2FSPAN%3E%3C%2FDIV%3E%3CBR%20%2F%3E%3CDIV%3E%3CSPAN%3E%23%20Link%20Options%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3Etarget_link_options(%24%7BEXECUTABLE%7D%20PRIVATE%20%26nbsp%3B%24%7BLINK_SCRIPTS%7D)%20%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E***************************************************************************************************************%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3EHow%20to%20use%20IDE%20debugging%20correctly%EF%BC%8C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EKind%20Regards.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%26nbsp%3B%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2177792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20S32DS%20IDE%3A%20CMake%20project%20Debug%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2177792%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F228205%22%20target%3D%22_blank%22%3E%40Bruce_Ye%3C%2FA%3E%26nbsp%3B%20hello%2C%20may%20I%20ask%20you%20a%20question%3F%3CBR%20%2F%3Ehow%20to%20import%20the%20source%20code%20into%20the%20S32DS%20ide%3F%3CBR%20%2F%3Ewhen%20I%20import%20the%20elf%20which%20is%20generated%20by%20ghs%20into%20S32DS%2C%20but%20when%20I%20download%20the%20elf%20into%20MCU%2C%20I%20can%20not%20see%20the%20source%20code%20%2C%20only%20see%20the%20assembly%20code%3F%3CBR%20%2F%3Ethanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1819430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20IDE%3A%20CMake%20project%20Debug%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1819430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20your%20help.%26nbsp%3B%3C%2FP%3E%3CP%3E%22%3CSPAN%3EProblems%20could%20be%20experienced%20while%20debugging%20of%20elf%20file%20generated%20by%20GHS%20compiler%20like%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Emissing%20call%20stack%20information%2C%20incorrect%20info%20on%20step%20into%20function%2C%20etc.%22.%26nbsp%3BIt%20is%20indeed%20here%20that%20caused%20the%20problem.%20I%20encountered%20the%20same%20issue%20during%20debugging%20when%20deleting%20gstrip%20-%20r%3D.%20debug_frame%20%24%7BProjName%7D.%20elf%20in%20the%20S32DS%20compiled%20project.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ENext%2C%20I%20need%20to%20add%20relevant%20commands%20to%20my%20CMakeLists.txt.%20I%20hope%20everything%20goes%20smoothly.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1817434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20IDE%3A%20CMake%20project%20Debug%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1817434%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EThis%20issue%20is%20probably%20related%20to%20a%20known%20issue%20listed%20in%20the%20S32DS%20release%20notes%3A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FS32-Design-Studio-for-S32-Platform-v3-4-Windows-Linux-released%2Fta-p%2F1206337%3Fattachment-id%3D107423%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FS32-Design-Studio-for-S32-Platform-v3-4-Windows-Linux-released%2Fta-p%2F1206337%3Fattachment-id%3D107423%3C%2FA%3E%3C%2FP%3E%3CP%3EStep%20out%20work%20incorrect%20with%20dbg_derived_types%20source%3A%20The%20GHS%20toolchain%20does%20not%3CBR%20%2F%3Egenerate%20DWARF%20Call%20Frame%20information%20that%20is%20suitable%20for%20unwinding%20the%20call%20stack.%20For%3CBR%20%2F%3Ethird-party%20debuggers%20incapable%20of%20unwinding%20the%20call%20stack%20through%20an%20alternate%20means%3CBR%20%2F%3E(disassembling%20code)%2C%20this%20may%20nullify%20the%20ability%20to%20walk%20the%20call%20stack%20or%20view%20variables%20saved%3CBR%20%2F%3Ein%20previous%20frames.%20As%20a%20workaround%20S32DS%20removes%20the%20debug%20frames%20info%20to%20force%20GDB%20client%3CBR%20%2F%3Eto%20recreate%20the%20frames.%20In%20some%20cases%20this%20method%20may%20not%20work%20and%20lead%20to%20incorrect%20behaviour%3CBR%20%2F%3Efor%20Step%20out%20command.%3CBR%20%2F%3E%3CSTRONG%3EWorkaround%3C%2FSTRONG%3E%3A%20Set%20a%20breakpoint%20at%20function%20end%20and%20run%20to%20breakpoint%3C%2FP%3E%3CP%3ESimilar%20issue%20was%20pressent%20in%20S32DS%20for%20arm%2Fpower%3A%3C%2FP%3E%3CP%3EProblems%20could%20be%20experienced%20while%20debugging%20of%20elf%20file%20generated%20by%20GHS%20compiler%20like%3CBR%20%2F%3Emissing%20call%20stack%20information%2C%20incorrect%20info%20on%20step%20into%20function%2C%20etc.%3CBR%20%2F%3E%3CSTRONG%3EWorkaround%3C%2FSTRONG%3E%3A%20On%20occasion%20GHS%20generates%20GDB%20incompatible%20debug%20information%20preventing%20the%3CBR%20%2F%3Edebugger%20from%20displaying%20the%20call%20stack.%20In%20some%20cases%2C%20without%20such%20information%20gdb%20can%20still%3CBR%20%2F%3Edebug%20your%20program.%20The%20program%20build%20needs%20to%20be%20augmented%20with%20a%20post-build%20step%2C%20select%20the%3CBR%20%2F%3Eproject%20in%20the%20project%20explorer%20view%20and%20File-%26gt%3BProperties%20to%20display%20the%20project%20properties%2C%20under%3CBR%20%2F%3EC%2FC%2B%2B%20Build%20-%26gt%3B%20Settings%20select%20the%20build%20steps%20tab%20and%20enter%20the%20command%20gstrip%20%E2%80%93%3CBR%20%2F%3Er%3D.debug_frame%20executable.%20Switch%20to%20Instruction%20Stepping%20Mode%20to%20be%20able%20to%20step%20through%3CBR%20%2F%3Efunction.%20If%20this%20workaround%20does%20not%20help%20%E2%80%93%20please%20report%20issue%20to%20GreenHills%20support.%3C%2FP%3E%3CP%3EHope%20it%20helps.%3C%2FP%3E%3CP%3EStan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1789409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32DS%20IDE%3A%20CMake%20project%20Debug%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1789409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThe%20following%20is%20the%20engineering%20log%20of%20IDE%20using%20the%20GHS%20compiler%EF%BC%9A%3C%2FP%3E%3CP%3E******************************************************************************%3C%2FP%3E%3CP%3EFinished%20building%3A%20..%2Fsrc%2Fmain.c%3CBR%20%2F%3E%3CBR%20%2F%3EBuilding%20file%3A%20..%2FProjectcode%2FMcal_config%2Fsrc%2FClock_Ip_Cfg.c%3CBR%20%2F%3EInvoking%3A%20GHS%20C%20Compiler%20for%20ARM%20Standalone%3CBR%20%2F%3Eccarm%20-preprocess_assembly_files%20-c99%20--gnu_asm%20-g%20-dwarf2%20-Onone%20-DSTART_FROM_FLASH%20-DS32K3XX%20-DENABLE_FPU%20-DLTC_ISOFT_CUSTOM%20-DINIT_STDBY_RAM%20-DARMCM7_SP%20-D__ITCM_INIT%20-D__DTCM_INIT%20-D__ghs__%20-DGEELY_SPECIFICATION_USED%3D1%20-DDISABLE_MCAL_INTERMODULE_ASR_CHECK%20-DBTB_ENABLE%20-DUSING_OS_AUTOSAROS%20-DS32K344%20-DGHS%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CExtend%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CCommonInclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CKernel%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CPlatform%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CBSW_Config%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CBase_TS_T40D34M10I0R0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CBase_TS_T40D34M10I0R0%5Cheader%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CBase_TS_T40D34M10I0R0%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CBase_TS_T40D34M10I0R0%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CDet_TS_T40D34M10I0R0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CDet_TS_T40D34M10I0R0%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CDet_TS_T40D34M10I0R0%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CMcu_TS_T40D34M10I0R0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CMcu_TS_T40D34M10I0R0%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CMcu_TS_T40D34M10I0R0%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cbuild_files%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cbuild_files%5Cghs%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cstartup%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cstartup%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cstartup%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cstartup%5Csrc%5Cm7%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CPlatform_TS_T40D34M10I0R0%5Cstartup%5Csrc%5Cm7%5Cghs%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CRte_TS_T40D34M10I0R0%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CRte_TS_T40D34M10I0R0%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal%5CRte_TS_T40D34M10I0R0%5Csrc%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal_config%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal_config%5Cinclude%22%20-I%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CProjectcode%5CMcal_config%5Csrc%22%20-cpu%3Dcortexm7%20-fsingle%20-thumb%20-MD%20-c%20-o%20%22Projectcode%2FMcal_config%2Fsrc%2FClock_Ip_Cfg.o%22%20%22..%2FProjectcode%2FMcal_config%2Fsrc%2FClock_Ip_Cfg.c%22%3CBR%20%2F%3E%22D%3A%5CD%5Cworkpalce%5CS32k344%5CS32K344_DEMO_20%5CPlatform%5CArch_Define.h%22%2C%20line%2066%3A%20warning%20%231-D%3A%3CBR%20%2F%3Elast%20line%20of%20file%20ends%20without%20a%20newline%3CBR%20%2F%3E%2F*%3D%3D%3D%3D%3D%3D%3D%5BE%20N%20D%20O%20F%20F%20I%20L%20E%5D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D%3D*%2F%3CBR%20%2F%3E%5E%3C%2FP%3E%3CP%3EFinished%20building%3A%20..%2FProjectcode%2FMcal_config%2Fsrc%2FClock_Ip_Cfg.c%3C%2FP%3E%3CP%3E************************************************************************************************%3C%2FP%3E%3CP%3EBuilding%20target%3A%20S32K344_DEMO_20.elf%3CBR%20%2F%3EInvoking%3A%20GHS%20C%20Linker%20for%20ARM%20Standalone%3CBR%20%2F%3Eccarm%20--gnu_asm%20-g%20-dwarf2%20-T%20%22D%3A%2FD%2Fworkpalce%2FS32k344%2FS32K344_DEMO_20%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fbuild_files%2Fghs%2Flinker_flash_s32k344.ld%22%20-e%20Reset_Handler%20-nostartfiles%20-cpu%3Dcortexm7%20-thumb%20-o%20%22S32K344_DEMO_20.elf%22%20.%2Fsrc%2Fmain.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FClock_Ip_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FClock_Ip_PBcfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FIntCtrl_Ip_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FMcu_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FMcu_PBcfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FOsIf_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FPlatform_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FPlatform_Ipw_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FPower_Ip_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FPower_Ip_PBcfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FRam_Ip_Cfg.o%20.%2FProjectcode%2FMcal_config%2Fsrc%2FRam_Ip_PBcfg.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Adc.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Can.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Crc.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Crypto.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Dio.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Eth.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_EthSwt_43_SJA11XX.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_EthTrcv_43_PHY.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Fee.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Fls.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Gpt.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_I2c.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_I3c.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Icu.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Iseled.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Lin.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Mcl.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Mcu.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Ocu.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Port.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Pwm.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Rm.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Sai.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Sbc_fs26.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Sbc_fs86.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Sent.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Spi.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Uart.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Wdg.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Wdg_43_fs26.o%20.%2FProjectcode%2FMcal%2FRte_TS_T40D34M10I0R0%2Fsrc%2FSchM_Wdg_43_fs86.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fm7%2Fghs%2FVector_Table.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fm7%2Fghs%2Fstartup_cm7.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fm7%2Fexceptions.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fm7%2Fstartup.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fnvic.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fsys_init.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fstartup%2Fsrc%2Fsystem.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fsrc%2FIntCtrl_Ip.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fsrc%2FPlatform.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fsrc%2FPlatform_Ipw.o%20.%2FProjectcode%2FMcal%2FPlatform_TS_T40D34M10I0R0%2Fsrc%2FSystem_Ip.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Data.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Divider.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_DividerTrigger.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_ExtOsc.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_FracDiv.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Frequency.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Gate.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_IntOsc.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Irq.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Monitor.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Pll.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_ProgFreqSwitch.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Selector.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FClock_Ip_Specific.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FMcu.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FMcu_Dem_Wrapper.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FMcu_Ipw.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_CortexM7.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_FLASH.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_MC_ME.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_MC_RGM.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_MC_RGM_Irq.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_PMC.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_PMC_Irq.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FPower_Ip_Private.o%20.%2FProjectcode%2FMcal%2FMcu_TS_T40D34M10I0R0%2Fsrc%2FRam_Ip.o%20.%2FProjectcode%2FMcal%2FDet_TS_T40D34M10I0R0%2Fsrc%2FDet.o%20.%2FProjectcode%2FMcal%2FDet_TS_T40D34M10I0R0%2Fsrc%2FDet_stub.o%20.%2FProjectcode%2FMcal%2FBase_TS_T40D34M10I0R0%2Fsrc%2FOsIf_Timer.o%20.%2FProjectcode%2FMcal%2FBase_TS_T40D34M10I0R0%2Fsrc%2FOsIf_Timer_System.o%20.%2FProjectcode%2FMcal%2FBase_TS_T40D34M10I0R0%2Fsrc%2FOsIf_Timer_System_Internal_Systick.o%20.%2FProjectcode%2FBSW_Config%2FOs_Cfg.o%20.%2FProjectcode%2FBSW_Config%2FOs_Intvet.o%20.%2FProjectcode%2FBSW_Config%2FOs_Kdata.o%20.%2FProjectcode%2FBSW_Config%2FOs_UserInf.o%20.%2FPlatform%2FArch_Extend.o%20.%2FPlatform%2FArch_Irq.o%20.%2FPlatform%2FArch_Mpu.o%20.%2FPlatform%2FArch_PendSV.o%20.%2FPlatform%2FArch_Processor.o%20.%2FPlatform%2FArch_Timer.o%20.%2FPlatform%2FArch_Trap.o%20.%2FKernel%2FOs_Alarm.o%20.%2FKernel%2FOs_Appl.o%20.%2FKernel%2FOs_Core.o%20.%2FKernel%2FOs_Counter.o%20.%2FKernel%2FOs_Event.o%20.%2FKernel%2FOs_Hook.o%20.%2FKernel%2FOs_Interrupt.o%20.%2FKernel%2FOs_Ioc.o%20.%2FKernel%2FOs_Kernel.o%20.%2FKernel%2FOs_Mprot.o%20.%2FKernel%2FOs_Panic.o%20.%2FKernel%2FOs_Peripheral.o%20.%2FKernel%2FOs_Resource.o%20.%2FKernel%2FOs_Rpc.o%20.%2FKernel%2FOs_ScheduleTable.o%20.%2FKernel%2FOs_Spinlock.o%20.%2FKernel%2FOs_Sprot.o%20.%2FKernel%2FOs_StackMonitor.o%20.%2FKernel%2FOs_Task.o%20.%2FKernel%2FOs_Tprot.o%20.%2FExtend%2FOs_Extend.o%3CBR%20%2F%3EFinished%20building%20target%3A%20S32K344_DEMO_20.elf%3C%2FP%3E%3CP%3E**********************************************************************************************%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Bruce_Ye_0-1705398814437.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bruce_Ye_0-1705398814437.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F258365i2AA72B2EA6D5644B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Bruce_Ye_0-1705398814437.png%22%20alt%3D%22Bruce_Ye_0-1705398814437.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EBruce_Ye_0-1705398814437.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E**********************************************************************************************%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Bruce_Ye_1-1705398847049.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Bruce_Ye_1-1705398847049.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F258366i46E3E3D3646BAC9E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Bruce_Ye_1-1705398847049.png%22%20alt%3D%22Bruce_Ye_1-1705398847049.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EBruce_Ye_1-1705398847049.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
