S32DS 2.2 ProcessorExpert.pe is disabled
Zhuang
Hello Teams,
I found a very strange thing in the customer, I click the generate code, but it tells me that ProcessorExpert.pe is disabled, and my pins, peripherals, clock can not be configured, inside is gray
It also shows that the Selected processor does not support the SDK,The picture is attached.
Zhuang
jiri_kral
do you have installed one of S32K1xx SDK (v3.0.0 or v3.0.3)?
Zhuang
Of course, my version is SDK3.0.0, and I open routines in RTD as normal.
This fault project was copied from my colleague and found that the bottom layer could not be changed.
jiri_kral
Did your colleague use the same SDK version?
jiri_kral
can you please share screenshot with processor expert settings (Right click on project name -> Properties -> Processor Expert
Zhuang
Hi  jiri_kral,
The attached picture is the interface where I opened Properties-Processor Expert, which shows the Selected processor does not support SDK
